TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Popetrout on March 24, 2015, 09:53:15 AM
Does anyone know the HES replacement part # from Honeywell that I could solder in?
original 2AV24 Honeywell, or imitation CYHME56 from www.Chengyang.de
thanks, do know of a good site to buy the whole hall effect sensor
at a discount? would like to avoid paying $4-500
http://www.hallsensors.de/Hall-Vane.htm (http://www.hallsensors.de/Hall-Vane.htm)
http://www.bbautomacao.com/home_hall_effect_sensor_cyhme56.html (http://www.bbautomacao.com/home_hall_effect_sensor_cyhme56.html)
Somewhere in here is a contact for vane sensors and upgraded wires for the HES. Seems that R1100's use the same units and have failures based on undersized wiring insulation. If you dig around you should find the post
Much thanks!...would the CYHME56C be a better option since it has better resistance to magnetic interference? any tricks to the switch out? does my gremlin bell help prevent this type of thing happening again?
