TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: beemuker on March 16, 2015, 08:00:53 PM
Title: will these bar extenders work...? K75s
Post by: beemuker on March 16, 2015, 08:00:53 PM
These bar extenders came with my K75s, and I think I would benefit from the extension as I would prefer not to lean forward as much. I don't want to get started on it and then find out I need tons of mods. looks like all I would need is a longer brake line. shouldn't be much trouble to get one made. ???? advice
Title: Re: will these bar extenders work...? K75s
Post by: Chaos on March 16, 2015, 08:13:24 PM
Looks sort of similar  to the one I have.  Brake line should be the only issue, some bike are OK with the stock line.  You'll need to fudge the back cover to fit the higher dashboard which mounts to the front of the riser (can't see in photo, it should have holes tapped in to mount the dashboard)
Post by: beemuker on March 17, 2015, 11:37:34 AM
thanks, is it necessary to get the brake fluid out before removing the line. I don't want to get fluid everywhere.
Post by: beemuker on March 20, 2015, 12:06:42 PM
got them on, only mod needed is the remove mounting brackets and find another way to attach instrument panel.
the brake hose is barely long enough. I'm going to ride it and see if it is improvement before I mod anything.
Post by: johnny on March 20, 2015, 02:04:35 PM
with barbacks... because of new stress point... rubber oem brake hoses are known to bust open at the banjo where the metal is crimped to the rubber...
Post by: beemuker on March 20, 2015, 02:57:37 PM
I like them and I think I'll keep them on, I've heard the K75c hose  is is longer. if that's what I need, where is the best place to get one?
Post by: johnny on March 20, 2015, 04:16:20 PM
local hose man can make you a set of stainless hoses... mystic red had a set made in spokane... id stay away from oem rubber hoses...
Post by: beemuker on March 20, 2015, 04:49:39 PM
thanks, my local napa doesn't make hoses. Spokane is 3 hrs away. Maybe I can find a closer source. Omak, or Wenatchee?
Post by: richarddacat on March 20, 2015, 09:01:51 PM
I've guess you checked to make sure that they don't touch the tank.  :yow
I had a set like those that the bottom edge just did touch the tank but that was on an old airhead.
Post by: beemrdon on November 19, 2015, 04:10:57 PM
Looking for a bar-back with drilled holes for dash pad. Anyone?
Post by: beemuker on November 20, 2015, 12:37:13 PM
since this post popped up again,
 I removed the barbacks and turned the stock S bars down and am trying the "yoda" position. I think I like it that way, but I haven't ridden the brick much since the cold weather hit. No snow, but the high is only in the 30"s today. I'm a wimp,l but I was raised in Miami so I come by it honestly.
I still need brake lines as I will remove the dead ABS [dead brain] this winter. Anyone know where I can order a  whole SS  set online? I will probably need measurements too. I'm sure a few of you have done this to a K75s. Is there a step by step "how to" posted somewhere? especially where to route the new lines, or is that pretty obvious? I'm pretty good at following directions, not so good at winging it on my own.
Post by: buddymack on January 06, 2016, 01:38:53 AM
Find the import tuner / dyno shop in your town.  They likely can point you to someone local who makes SS lines.  The banjo ends are the tricky part.
Post by: K1300S on January 06, 2016, 06:13:59 AM
I pulled the barbacks on my S also.   Much better.
Search on "stieger" for brake lines.  Think that is right spelling for company that makes them.  About 175 bucks.  I am about to order a set.
Can relate to the cold issue.  Lived in Miami for 15yrs.
Post by: beemuker on January 06, 2016, 10:55:03 AM
confused as to which kit to order as I am getting rid of the nonfunctional abs at the same time.
Post by: K1300S on January 06, 2016, 04:53:17 PM
then get the kit for a non-abs bike.
