TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: mystic red on June 18, 2011, 04:58:39 PM
How do you adjust the idle on a K1100? Is it possible? I got mine back together after rehabbing the intake manifolds and it idles a little high now. I thought syncing the throttle bodies would take care of it but if anything it gets higher the closer I get to getting it synced.
i adjust my idle with the choke lever...
sent from johnnys droid
You can adjust the cable up at the throttle perch end. Pull the boot back.
I adjusted the throttle cable so there is a little free play already. No love.
When syncing the TB #1 is the front most TB, right?
Yes, the forward cylinder is number one. You could use any TB as your reference TB though.
You sure you don't have a vac leak somewhere. That will give u a high idle.
He just replaced the stuff above and below the TBs to fix an air leak.
Mystic Rod: My bikes idle a little fast. I don't care.
mystic reb...
how many rpms you got on idle... the motoheap idles at 1500 rpms with the choke lever closed...
bye the way... that choke lever is a proficient cruise controller...
I know. Still doesn't mean he couldn't have missed something. BTDT
To lower the idle you could turn ALL the brass adj screws in equally.
You're kidding me, right? That's what started this whole thing. ;)
No it's not that high, maybe 1200 RPMs.
Duck, why do you open the brass screw 1 1/2 turns? The reason I ask is when they are more closed the idle is lower.
#1 is the only one that I can't zero so I am using #4 as a constant. Then 2 and 3 will zero to 4. Don't know why #1 is being a pain in the ass.
Edit: just read the above posts. Missed em earlier. Will check for leak and try the brass screw thing later. Thanks.
mystic reb... the bug has never idled less than 1500 rpm n you know that moe screams like a stump hugging big giant poodle...
If you can't synch #1 then you might still have an air leak. Git yer propane out.
I do one and a half turns because I read it in an Eilenberger post somewhere and he knows more about this stuff than I do.
Another thought came to my mind.
When was the last time you checked your valve clearances?
Probably just a burned valve or leaking head gasket. Nothing to worry about.
Did the propane. Negative. Used the #4 as a constant, backed out 1 turn which lowered the idle. #3 & #4 synched at about 1 turn out and #1 3 turns out.
Valves were checked about 20K ago, should be good.
They are synched now at the specified turns. Don't know why #1 is out so much but I had a tech do it once a few years ago and he said he had problems also in getting right to specs. What do ya think? Good to go?
Aren't you just a ray of sunshine. ;D
Just yanking your chain. Exhaust valves are subjected to a lot more heat than intake valves
dude... get aaa with the 200 mile tow n ride it till it wont move...
From the BMWOA guru:
One turn is enough and three not excessive provided they are balanced and the idle is acceptable. Number 1 out three turns is a sign that #1 draws a bit less air than the other three. Valve stem/head deposits maybe. Nothing to worry about but check it again in 5K miles or so (or whenever) to see what is changing if anything.
__________________
Paul Glaves - "Big Bend", Texas U.S.A
"The greatest challenge to any thinker is stating the problem in a way that will allow a solution." - Bertrand Russell
http://www.bigbend.net/users/glaves (http://www.bigbend.net/users/glaves)
So I'll take our guru's advise and "ride it till it won't move."
If Glaves says one is enough then that's good enough for me.
You might want to take #1 out and see if it's dirty. They just screw right out and right back in. Not a bad idea to clean all of them while you're at it. While you have them out you can polish their tops with a Dremel to make them all shiny. 8)
Good idea, I'll check them out.
MR, if you say that your previous mechanic also commented on having troubles with #1 the same as you are, almost sounds to me like a butterfly adjustment could improve the situation.
You know the painted screws your "not supposed" to touch.
Hi Scott, yea Clymers says to throw your $800 plus throttle assembly away if you have touch these. ;D
Got a link to the procedure handy?
I'll take a look on my other computer, but I think I have a pdf on it somewhere. I also think I sent Drake a copy of it a while back.
It had been posted on IBMWR a number of years ago but was removed.
Underscore: If'n you find it then please post it in the Lieberry as an atttachment. (Click "Additional Options..." below the posting text box.)
I replied to your write-up and attatched it there.
Great. Thanks.
Thanks Scott! Something to mess with this winter. Don't think I'm going to mess with it til then.
They do seem a little out of adjustment. If I just push down on the throttle rail with my finger the idle goes down to were it should be. Nothing holding it up, it just doesn't quite close.
Doesn't hurt to spray some silicone lubricant on the return springs.
From the way the article was written, it sounds like the author was working on a K75.
When I did my 2 bikes IIRC I used cyl #3 as my base because the throttle cable attaches to that butterfly most directly without adjustable linkage in between the butterfly and the cable attachment.
I set my throttle lock and went from there. 3 to 4, then 3 to 2, and finally 3 to 1. After that then the brass screws were adjusted for fine balance and final idle set. All using just my TwinMax.
If I had made any adjustment to #4 I then also checked my TPS settings, and choke settings last.
Like Dr.Duck suggested a little lubrication doesn't hurt, make sure all is freed up.
Disclaimer: K75RT is my first bike and right now I don't know enough to be good on the diagnostics, just good enough to be dangerous. Anyway, What you just described above is what mysteriously happened to my K75. What I found was causing it but have no idea how it happened, is the TPS moved by itself to do just that: The TPS was turned CW enough to slightly hold the throttle rail open, which I could close and bring idle down to normal by pressing on the throttle linkage. While checking for every kind of linkage hangup, I finally removed the TPS and discovered the idle was correct with it off. I reattached TPS, reset and tightened it up, and all's well ...... except for the inadvertent turn I made to the blue painted screw between #2 and #3 TB. :( Still wondering how to proceed with that, even after reading the PDF attachment over on the TB synch thread.
Excuse my ignorance but what is CW?
Clockwise
