MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: armoredveh on February 23, 2015, 12:11:33 PM
I purchased this shock off of EBay only to find, after I had it rebuilt by Ohlins, that it raises the rear of my 1995 K75 ABS by about a 1 inch (30mm).
The Ohlins model number is a BM002 Type 46HRCS and while it will work on K75/K100s (it actually came off of a very low mileage K75RT), it's made for 1990-1992 BMW K100RS and K100RS ABS. If interested or unclear if this shock will work, my suggestion would be to measure the length of your current shock -- this one measures 352cm eyebolt to eyebolt.
Cosmetically this shock looks new with very little patina showing and after being completely rebuilt by Ohlins in December, has not been used. I will send the Ohlins invoice upon request. Asking $850 (which includes ground shipping).
For questions or high-res pics, please email me armoredveh@aol.com.
TIA, Bill Shaw
You may want to indicate where you are located when selling something...
i just gotts my motobrick.com dividend check so my wadd is thick... before i peel off 9 hunderts i gotts to ask... what is that spring rated for in pounds...
yeeeehaaaaa...
Brad-Man, I live in Northern VA just outside of WDC...but I'm paying for the shipping if that makes any difference.
Johnny, I just check with an Ohlins tech and the number stamped on the spring is 1099-09, which means the spring rate is rated at 50 N/mm or 286 ibs/in. He also said it's standard spring rate so it hasn't been replaced with a softer or harder one.
HTH, Bill Shaw
rodger that...
im out... just my brain alone weighs 287 pounds... and i needs my right hand and left foot to proficiently motobrick...
