TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: vesku on February 22, 2015, 07:34:59 AM
Hi all. After swapping my driveshaft I noticed the wire from the speed sender unit is pretty badly damaged due to excessive heat caused by the scratching in the driveshaft casing. Can I replace the wire with any ole length of wire hanging around? Or is it something special? Or maybe somebody has a known good sender fs? TIA,
V
what moto... gotts a photo to post...
if its the wire that goes into the top of the final drive near the shock... i thinks its special and need to go oem on the whole shebang... i had one getts rubbed open... soldered it back together and it didnt work... was told its some kinda special resistance wire... replaced the whole shebang and all was well...
(http://www.redlandcycles.com/public_html/motorcycle/2015_01_05/IMG_4065.JPG)
Yes, that's the one. K100RS -85. Dang, but luckily found already one off fleabay for under 50 Euros shipped. Thanks!
