MOTOBRICK.COM => The MBdotCOM Community Center => Topic started by: TimTyler on November 02, 2014, 11:16:08 AM
Title: Only 85 More Years to Use Your K-Bike
Post by: TimTyler on November 02, 2014, 11:16:08 AM
Fossil fuels should be phased out by 2100 says IPCC
http://www.bbc.com/news/science-environment-29855884 (http://www.bbc.com/news/science-environment-29855884)
 :riding: Get riding!   :riding:
Title: Re: Only 85 More Years to Use Your K-Bike
Post by: johnny on November 02, 2014, 12:22:36 PM
i have already converted to cannagas... by product of refining cannaboil...
its 35 degrees and sunny... going for ride... ha ha ha...
Post by: wmax351 on November 03, 2014, 04:25:15 PM
Convert them to run on ethanol. By then we should have figured out cellulosic ethanol production, which eliminates the issues and inefficiencies of using corn to produce it.
http://www.wolframalpha.com/input/?i=%28133+cc%2Fminute+*+.76+g%2F+cm%5E3+*+14.7%2F9%29+%2F++%28.79+g%2Fcm%5E3%29 (http://www.wolframalpha.com/input/?i=%28133+cc%2Fminute+*+.76+g%2F+cm%5E3+*+14.7%2F9%29+%2F++%28.79+g%2Fcm%5E3%29)
All that would be required is to use ethanol proof fuel hose, pump damper, and a 209 cc/minute injectors/pressure reg setup, rather than our 133 cc/minute @ 35 psi ones. Put a normal 43.5 psi regulator in, and some standard 20 pound an hour injectors, and you're golden.  While you're at it, you could bump the compression ratio and timing a bit. Would give more power, beyond the increase already there from the ethanol.
Post by: Photog on November 03, 2014, 05:29:38 PM
I guess that will be as good a reason as any to give up riding the motobrick when I'm 145.
Post by: Brad-Man on November 03, 2014, 10:12:43 PM
Then triple the size of the gas tank....
