TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Cliff on September 28, 2014, 11:45:40 AM
Title: 1988 K100
Post by: Cliff on September 28, 2014, 11:45:40 AM
Hi, From Cliff NZ. I am considering buying a 1988 K100. Any info on parts that are interchangeable with a 1992 K1100LT/ABS, eg. front disc rotors, wheels, crash bars, etc. The K100 has only done 27,000 kilometres from new and is in good condition except has a seized clutch. Photo attached.
Cheers
Title: Re: 1988 K100
Post by: kioolt on September 28, 2014, 12:18:18 PM
I may be mistaken but that pictures looks like it's got 1985 K bike sidecovers and foot peg plates.
Post by: Inge K. on September 28, 2014, 12:23:30 PM
+1.........also seat , ducktail and fork.
Post by: Inge K. on September 28, 2014, 12:32:45 PM
Hi, From Cliff NZ. I am considering buying a 1988 K100. Any info on parts that are interchangeable with a 1992 K1100LT/ABS, eg. front disc rotors,different dia and hub wheels,rear, OK...front, different axle and spacers crash bars,you can use the one from the K11 on the K100, but not the other way around etc. The K100 has only done 27,000 kilometres from new and is in good condition except has a seized clutch
What is the VIN?
Post by: Cliff on September 28, 2014, 12:37:53 PM
Hi, k100lt, You may be right, I don't know enough about "K's" to tell the difference. But for the price, $ 300.00 NZD ( approx. $ 235.00 USD ) its a real cheap K. If the cost of "un seizing clutch" is not too much, I will get it back on the road, other wise I will use what parts I can for my 1992 K1100LT.
Is the 1988 ?/1985 clutch replacements very expensive for parts ?.
Post by: Cliff on September 28, 2014, 12:40:03 PM
Hi, Thanks for the info, I will check the "VIN" number.
Cheers
Post by: Inge K. on September 28, 2014, 12:45:13 PM
Search Motobins and Motorworks for prices, I know from other forums that for the Aussies it's cheaper to have the parts sendt from UK than bought home in OZ.
Post by: Inge K. on September 28, 2014, 12:52:30 PM
Very few of the parts is identical.........some instrument internals, some relays, tail light and rear flashlight.
Post by: kioolt on September 28, 2014, 01:00:11 PM
What do you mean by seized clutch?
Post by: Inge K. on September 28, 2014, 01:05:54 PM
I would guess that the pressure plate(s) and friction disc is glued together, due to not been used for many years.
Post by: kioolt on September 28, 2014, 01:30:00 PM
I once had a Cub Cadet riding mower do that where I worked at the time about 30 years ago.  I was able to unstick it by driving it with the clutch pedal depressed.  It eventually released.
Post by: Cliff on September 28, 2014, 01:33:06 PM
HI, Thanks for all the info. I will check what is the clutch problem ( when I can contact the seller ) The bike is in another city/part of NZ. I appreciate all your replies. Thank you.
Post by: bocutter Ed on September 28, 2014, 01:49:05 PM
Ulysses Club "Grow Old Disgracefully"
Love it.  :hehehe
Post by: beachcomber on September 28, 2014, 04:05:56 PM
I'm assuming you have a K1100 parts bike ?
Forks and complete front end will swap over - as will rear wheel giving you  bigger stanchions,better suspension and 4 pot calipers.
ABS - your choice - I spent all my Kay life throwing the stuff away !!
"Seized" clutch sounds like a "frozen" clutch with plates stuck together through standing
Post by: pdg on October 04, 2014, 06:46:18 AM
From what I understand, it's the other way round - he has a k11 already and was considering the k100 for a parts donor...
Post by: Inge K. on October 04, 2014, 06:56:09 AM
+1.
