TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: grant71 on September 12, 2014, 04:46:18 PM
Title: oily leak
Post by: grant71 on September 12, 2014, 04:46:18 PM
hello everybody. Today i  noticed an oily leak on no. 4 throttle body rubber just below the very bottom silver clamp. the clamp looks like a factory fitted item . Question is how does one remove these clamps and is a special tool required.  the oil is leaking out below the clamp. not much. just a droplet or two. any suggestions as to why there should be such a leak please
Title: Re: oily leak
Post by: johnny on September 12, 2014, 06:17:58 PM
i removed mine with a plasma cutter and blow torch...
Post by: rbm on September 12, 2014, 07:24:21 PM
Johnny, Johnny, Johnny .... <sigh> :nono
Oil could be coming from the air plenum.  Crank case vents into the air plenum so oil accumulates over time.  Remove and Clean the air plenum.  Use side nippers to cut the Oeitker clamps off, not a plasma cutter.
Post by: Motorhobo on September 12, 2014, 08:34:46 PM
I think I removed mine with regular wire cutters and small needlenose and twisting the f**k out of them. Eventually the oetiker binding will fail and you can pull them off. Lots of wrist work but fire-free.
Title: oily leak
Post by: Elipten on September 12, 2014, 10:27:18 PM
Dremel tool, with fine grinding disk.  Quick work, no twisting.
Post by: Inge K. on September 13, 2014, 05:19:07 AM
As RBM also says, crankcase breather is connected to the plenum chamber at cyl. 4....and this would be
the oil comes from.
This would be a lot worse if the engine is overfilled.....didn't you have some problem with the sight glass ?
The Picture showing a cutter made for cutting stainless clamps of the kind used on driveshaft boots on cars.
Post by: grant71 on September 13, 2014, 09:56:51 AM
thanks for your replies. does nt seem like a serious problem . Or can it develop into a problem? seems like a lot of work to open up and clean out the chamber. i ll periodically use a degreaser to remove oil on the clamps. no need i suppose to remove the clamp. the rubbers dont seem damaged. at least the bike is not misfiring.Eric? what is a Dremel tool?
Post by: Inge K. on September 13, 2014, 10:03:09 AM
http://en.wikipedia.org/wiki/Dremel (http://en.wikipedia.org/wiki/Dremel)
Post by: johnny on September 13, 2014, 10:04:35 AM
greetings grant71...
there a many dremmel tools... here are a few...
(http://www.wernermd.com/blog/wp-content/uploads/2013/10/Vibrators-008.jpg)
Title: oily leak
Post by: Elipten on September 13, 2014, 09:57:53 PM
Johnny funny and sick at the same time.  Lol
It is a little hand grinder, numerous tools to use in chuck.  Sander, buffer, saws, grinders, engraving bits an etc.
Post by: Motorhobo on September 13, 2014, 10:23:33 PM
Johnny, a Dremel is far too underpowered to get the job done with those attachments. Go with a sawzall. Demos at f**kingmachines.com.
Warning...highly inappropriate content there...visit at your own discretion. It's what's commonly referred to as 'pr0n'...but I kid you not -- sawzall attachments. Of course I've never actually visited the site...but living in Seattle you exposed to all kinds of kinky weirdness.
Don't blame me...Johnny started it!
Post by: grant71 on September 14, 2014, 03:34:08 AM
thanks for the Dremel tool explanations both serious and flippant. Johnny Whacker ! ! my name is Grant Murray not Hugh Hefner. but between us on this site i need a few of those magic tools. which one do you use Johnny?
