TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Diveschool on July 30, 2014, 01:26:13 PM
Title: Can I use this suspension?
Post by: Diveschool on July 30, 2014, 01:26:13 PM
The suspension on my 1992 k75rt, began to look worn out, and the dust cap had come off.  Can I use this bmw SHOWA B0272 suspension ( believe it coming from r1150rt) that I have?
It seems brand new.
Thank you
Title: Re: Can I use this suspension?
Post by: pdg on July 30, 2014, 02:34:29 PM
Do the mount bolts/studs fit through the eyes?
Is it of a suitable length to give you an acceptable ride height?
If those two are yes, stick it on and go for a little ride...
If you like it, or at least can adjust it how you like it, then use it - after all, it's a spring around a damper - it doesn't know if it's on the 'correct' bike...
Post by: F14CRAZY on July 30, 2014, 04:18:53 PM
Progressive can rebuild their rear shocks. I was quoted a max of $100
Post by: Motorhobo on July 30, 2014, 07:42:34 PM
That depends on the model. They wouldn't rebuild my 420 and the bladder and internal parts are no longer in production with no new parts entering the pipeline. Less expensive Progressives such as the 412 aren't rebuildable at all.
I was quoted that the 420 was rebuildable until I sent it out to be rebuilt and 3 weeks later received rod that parts were not available. So -- I am skeptical about progressive rebuildability claims.
Post by: subforry on July 31, 2014, 05:26:42 PM
The Showa my my K1100RS is not rebuild-able.  Give Terry at RaceTech a call about rebuilding shocks.
Post by: F14CRAZY on July 31, 2014, 08:49:59 PM
Hmmmm...Gerrad Capley of Progressive said my 412 can be rebuilt...I have that message in my email (I just haven't gotten around to obtaining a loaner shock and sending mine in). It is quite possible that I contacted someone there that doesn't know what they're talking about, but I did tell them it's a 412 on a K75  :falldown:
Post by: Motorhobo on August 01, 2014, 06:47:36 AM
http://xlforum.net/vbportal/forums/showthread.php?p=1764154 (http://xlforum.net/vbportal/forums/showthread.php?p=1764154)
http://xlforum.net/vbportal/forums/archive/index.php/t-23282.htm (http://xlforum.net/vbportal/forums/archive/index.php/t-23282.htm)
Progressive customers service is one of the reasons i will never buy another Progressive shock. if you get lucky and include a copy if the mail when you send it in, they'll send you a brand new one for your hundred bucks. If not, they'll send it back and say, 'Oops'.
Maybe call Progressive and ask for confirmation. The rep I talked to confirmed that the 412 was not rebuildable and the 420 was but that no parts were available so it effectively was landfill.
Post by: Diveschool on August 01, 2014, 09:23:32 AM
The progressive suspension I have on the bike, were do I find the model number?
I see mfg name only.
