TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Texbid on July 20, 2014, 03:31:25 PM
Title: sprag sprague clutch easy fix diy
Post by: Texbid on July 20, 2014, 03:31:25 PM
berts explanation of the sprag clutch is the lets analyze the principle behind a starter mechanism pdf at the bottom of this post...
this is texbids excellent post...
dreaded sprag cluch issue.  If you dont know what this is then search the forums.  This is my super cheap fix and done in about 40 minutes includes 20 minutes with flusihin oil and engine running..
parts needed
12mm drill
1/4 bsp plug with o ring (see below for the item i bought)
http://www.ebay.co.uk/itm/111268478093?var=410275065095&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 (http://www.ebay.co.uk/itm/111268478093?var=410275065095&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649)
flushing oil
http://www.ebay.co.uk/itm/231095282248?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 (http://www.ebay.co.uk/itm/231095282248?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649)
two oil filters
http://www.ebay.co.uk/itm/270776992221?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 (http://www.ebay.co.uk/itm/270776992221?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649)
drill hole as per pictures.
move gear through the window to align the flushing hole on the sparag clutch
you should see the hole as in the second picture.
spray into hole with wd-40
and it now works.
i then ran flushing oil in the engine until the fan turned on.
changed oil and no problems.
cap the hole with the bsp plug. no need to thread it.
(http://)
Title: Re: sprag sprague clutch easy fix diy
Post by: wmax351 on July 20, 2014, 04:50:12 PM
Interesting. How did you deal with swarf from the drill?
Seafoam Spray would be a lot better than WD40 for this application.
Post by: WayneDW on July 20, 2014, 09:34:18 PM
welcome.
great idea, thanks.
Post by: Texbid on July 21, 2014, 12:43:11 AM
Wmax,
The key was to use a very sharp drill. Then drill slowly and blow the swarf away with a compressor. IMO you don't need the compressor but it helps. The case material is soft so im small particles got into the engine it should be fine. They are bulletproof aren't they :).
Post by: beachcomber on July 21, 2014, 04:38:26 AM
Wmax,
I came to the same fix about 5 years ago ....... I used a blob of silicone gasket goo to drill through - that entangled all the swarf ! Good fix.
Post by: Tiny97 on July 22, 2014, 07:53:25 PM
Texbid any chance we could get a point of reference shot a lil further away from the hole? I'm not in front of my bike but I'm having a hard time visualizing exactly where the hole you drilled is.
Post by: Texbid on July 23, 2014, 01:03:22 AM
Tiny97
I have been doing a few things to the bike in order to resurect it. Water-oil pump rebuild, wiring harness replacement, etcetc.
The image needs to be rotated 90CW to be correctly orinted. There is no airbox on the bike either so it may be misguiding.
Once rotated yYou will see the outline of the right hand side engine cover, the one with BMW embossed. The hole is directly above the back top corner of the engine cover.  Hope that helps.
Post by: TimTyler on July 23, 2014, 04:52:35 PM
Is the right?
Post by: Texbid on July 23, 2014, 06:32:25 PM
Exactly correct.  Thanks for the. Assist.
Post by: Tiny97 on July 23, 2014, 07:59:51 PM
Wow thank you so much I was thinking it was a top down shot before. I've spent so much on oil changes every few hundred miles trying to fix this, this is a big help. I may be setting about to working on this this weekend. is the 1/4 bsp plug something I could find in a local hardware store or maybe auto parts store?
Post by: Texbid on July 24, 2014, 12:48:16 AM
I got mine from ebay. Check local plumbing supplies or maybe even home depot or BQ (depends what side of the Atlantic you are on)
See link above.  You could put anything into the hole. Even a regular bolt. Its not load bearing or pressure containing. It merely keeps the oil from splashing out.
Hope it works out for you..
Post by: wmax351 on July 24, 2014, 03:28:18 PM
A 3/8 (might be a smaller NPT size, though) npt tap comes with one of the cheap Harbor Freight tap/die sets. NPT is a tapered thread, and self sealing, especially with a little (carefully applied) teflon tape. Would be ideal for this location. You could even make the plug too, out of Aluminium rod: the matching die comes with the kit.
Post by: Texbid on July 25, 2014, 10:20:47 AM
I think the 3/8 hole will be too small. If the clutch oil hole, as shown through the hole in my case and between the gears on the photo below , is not aligned with the case hole the only way to make it align is by manually rotating the gear seen on the right hand side of the hole. You can rotate this with a aluminium rod(must be softer than the gear to avoid tooth damage)
(http://img.tapatalk.com/d/14/07/25/ta3eryhy.jpg)
Post by: Inge K. on July 25, 2014, 10:48:50 AM
I would guess it could be difficult, you also at the same time must turn the crank, cam, intermediate and gearbox input shafts.
It would be easier to turn the rear wheel, or remove the cover at the hall sensors and turn the crankshaft...
is my opinion.
Post by: TimTyler on July 25, 2014, 11:32:53 AM
Are the sticky sprags inside that smooth ring between the gears?
That hole is the only way oil gets in and out?
Post by: Texbid on July 25, 2014, 11:36:48 AM
Yes the sprags are inside the smooth part. Oil gets in by splashing action inside the case.
(http://img.tapatalk.com/d/14/07/25/aju6e7ev.jpg)
Post by: Texbid on October 09, 2014, 04:33:26 PM
Months later the fix still works.
Post by: johnny on October 09, 2014, 07:38:27 PM
greetings texbid...
highly sought after information... thanks for doing the leg work and posting up... this will come in handy for sure...
gonna getts this in the lieberry... and you will be world famous...
Post by: racinrich on October 12, 2014, 01:24:26 PM
2 questions what is the symptom of a sticky sprag and is this motor specific ie k75 or does this apply to all motors  :dunno
Post by: Texbid on October 12, 2014, 01:29:03 PM
Upon pressing the start button the starter spins but the engine does not. Its a whine that drives shivers down the back of all K bike owners as the entire motorcycle was built around the sprag clutch (sic).
Post by: racinrich on October 12, 2014, 01:41:11 PM
thanks  :curvy-road
Post by: joolx on May 22, 2015, 07:28:54 AM
I followed this post to the letter only to find that my starter clutch is the 3 roller type so after drilling the hole in the bell housing found no small hole in which to squirt the seafoam etc. However I did my best to cover  as much of the exposed innards as I could with the solvent and left it over night....Next day same issue
Then I thought about trying to vibrate it free so I took a bit holder, turned it the wrong way round and inserted it into my cordless drill. I set the mode to masonary so it would vibrate and as the tip is now just a smooth hexagonal shaft of metal it wouldn't do any damage. I then carefully placed the end against the exposed smooth starter clutch through the hole I'd drilled through the bell housing and gave it half a second of power.......Tried the starter button and hey presto it burst into life..
I will now follow the rest of the instructions...flush the engine...put in new Mobil 1 fully synth 15W50, new filter etc. I've had to buy a tap to cut a thread for the 1/4 bsp plug but thats no problem
Many Many thanks for saving me a lot of trouble
Post by: Texbid on May 22, 2015, 08:14:19 AM
glad to see that the fix has helped somebody else.  I haven't had any problems with mine since i implemented the fix.
On another note.  I don't think that the brick will benefit from fully synth oil IMO.
Btw.  A few pics of my bike.
Post by: Chaos on May 22, 2015, 08:33:34 AM
 :mbird
Post by: Conrad325i on March 11, 2016, 01:40:30 AM
I did this with a 3/8 npt and a pipe plug... worked like a charm. I sprayed wd40 in the little hole and then hit it with a hammer and punch.
Post by: The Mighty Gryphon on March 11, 2016, 08:41:41 AM
I had a problem with the sprag clutch after doing a head job and reassembling with moly assembly paste.  Never put anything with moly in it in the engine  After running fine for a week the sprag stopped working.  The moly paste had migrated into the oil.
I did an oil change with plain old 10W30 and put a full bottle of Sea Foam in the engine.  Did a backspin to engage the sprag clutch and took it out for a 20 mile run.  Came back and did another oil and filter change, and knock on wood, the starter has worked perfectly in the month since.
Post by: Conrad325i on March 15, 2016, 12:07:12 AM
That is good to know. I have yet to ride my new bike further than around the block because Im waiting on tires. But I have to tap on the spraque every single time I want to start the bike. And every time ive started it I have let it get up to opp temp... I guess it needs high rpms to fully lubricate that thing again...
Unfortunately I think mine is really really gummed up.
Like it was having problems and then the prev owner let it sit outside for 15 years lol
Post by: The Mighty Gryphon on March 15, 2016, 12:12:29 AM
Drain the oil and replace with some cheap 10W30 and a full bottle of Seafoam.  Run it hard for a half hour or so and do an oil change.  I was amazed at how dirty the oil was for such a short run time.  Sprag clutch is still working properly.
Post by: Conrad325i on March 15, 2016, 01:26:57 AM
As soon as my tires get here/mounted/balanced I will do just that. Thanks for the tip, gryph.
Post by: Conrad325i on March 16, 2016, 04:29:40 PM
So in a single post:
Step 1: Drill and Tap the crankcase to accept 1/4npt and buy a plug to go in it.
Step 2: Open oil filler cap
Step 3: Pour in 1/2 bottle seafoam
Step 4: Go for a ride
Step 5: Jump for joy when you can restart the bike without pulling your air filter and banging on the sprag        housing.
Post by: The Mighty Gryphon on March 16, 2016, 06:42:39 PM
Don't leave that Seafoam in there too long.  It thins the oil and that isn't good for the rubby parts.
Post by: Martin on May 21, 2017, 06:31:21 PM
No need for drilling I found this on another site, read it all.
 http://k-bike-knowledge.000webhostapp.com/mechanical/sprag_clutch/starter_clutch.htm
Post by: thecableguy on May 21, 2017, 07:06:55 PM
One other thing.  A weak starter can cause the sprag to slip.
I was having occasional horrid-sounding sprag noises and I tried several of the cleaning methods described here.  After months of trying to fix it that way, on a hunch I took a look at the starter brushes.  Immediately ordered a rebuild kit from the guys at Euromotoelectrics.  Rebuilt my starter and never had the sprag squeal again.
Just another thing to look at.  And rebuilding one of these starters is easy and cheap.
Jim
Post by: detbmw on June 20, 2021, 10:56:16 AM
The ebay link no longer works for the flushing oil. Was it Rislone? And do you add a quart, or fill it with just Rislone?
Thanks!
Post by: Laitch on June 20, 2021, 11:44:50 AM
Was it Rislone . . .? And do you add a quart, or fill it with just Rislone?
Considering the post with that link is seven years old, it might be more effective if you sent Texbid a PM through this site for a personal answer which you could post as an update for everybody.
Post by: Texbid on June 20, 2021, 01:06:53 PM
https://www.ebay.co.uk/itm/Engine-Flushing-Oil-Flush-Fluid-Cleaner-For-Petrol-Diesel-Engines-5-Litre-5L-/373537080247?_trksid=p2349624.m46890.l6249
Any cheap flushing oil will do.
Post by: Laitch on June 20, 2021, 05:21:16 PM
There's a dedicated member right there. ⬆︎
Post by: Texbid on June 21, 2021, 06:10:27 AM
Just trying to help.  I sold the brick many years ago, but remember the utter dismay at considering a full engine teardown for a simple fix.
And frankly I was quite shocked when I saw a response to this diy fix.  Good luck.
