TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Justdirt on July 09, 2014, 10:38:00 AM
Title: Odometer
Post by: Justdirt on July 09, 2014, 10:38:00 AM
On my 1994 K75, the speedometer and the tachometer works correctly, but the odometer and the trip meter is not turning during driving.  The reset knob is working correctly.  Could a wire be unplugged?  Possible fix?  I had the instrument panel rebuilt last year with new plastic numbers.  Any help will be appreciated.
Title: Re: Odometer
Post by: johnny on July 09, 2014, 11:02:32 AM
greetings justdirt...
welcome to motobrick.com...
thats whack... your new numbers not turning...
Title: Re: Odometer
Post by: koapono on July 09, 2014, 11:40:17 AM
speedo and tach work off electric signal.
odometer and trip meter are driven by plastic gears, an electric signal does cause the main shaft/gear cog to turn and that may have been damaged when numbers were replaced. link below, hi-jacked from liberry, shows various gear trains used.
reckon you'll have to disassemble instrument cluster and check wires/pin connectors and gear assembly.
tedious but after you've done it a few times it's like changing a light bulb!
g'luck
http://www.odometergears.com/products/BMW/R+%26+K+Motorcycles/42 (http://www.odometergears.com/products/BMW/R+%26+K+Motorcycles/42)
Title: Re: Odometer
Post by: Justdirt on July 09, 2014, 01:17:20 PM
g'luck
Thank you for the information and the link. :bmwsmile
Title: Re: Odometer
Post by: wmax351 on July 09, 2014, 02:00:16 PM
If it was rebuilt, whoever rebuilt it should fix this. I would assume they put the new gears in, or at least should have if they were either seemingly worn or soft. It's not too hard to replace them though.
Title: Re: Odometer
Post by: Justdirt on July 10, 2014, 05:36:45 PM
  I would appreciate any information on how to remove the Instrument Cluster off of the 1994 K75.  I will deliver to a speedometer shop for repair.  :bmwsmile
Title: Re: Odometer
Post by: Elipten on July 10, 2014, 06:50:44 PM
Look for my recent post on the repair shop in Austin that does this work
Title: Re: Odometer
Post by: Justdirt on July 10, 2014, 07:17:30 PM
I looked up the post and I thank you for the information. :bmwsmile
Title: Re: Odometer
Post by: Elipten on July 10, 2014, 07:18:45 PM
Welcome use my name when contacting.  He is good.
Title: Re: Odometer
Post by: Justdirt on July 10, 2014, 07:26:44 PM
Do you know of an "WWW Link" or You Tube Video on how to remove the Instrument Cluster from a 1994 K75?
Title: Odometer
Post by: Elipten on July 10, 2014, 08:17:03 PM
Not much to it but no doubt varies by model.  I can only speak for a 1990 K75RT.  What year and model do you have?
Title: Re: Odometer
Post by: Justdirt on July 10, 2014, 09:05:11 PM
I have the 1994 K75 basic version; no abs; no fairing; mine is red;  it is identical to the photo on the specs page for this web site.
Title: Re: Odometer
Post by: Elipten on July 10, 2014, 09:35:18 PM
Anybody help Justdirt?
Title: Re: Odometer
Post by: wmax351 on July 10, 2014, 09:51:29 PM
Removing them is pretty easy if there isn't a fairing. Remove the headlight bucket/assembly. Remove the cover for the wires (1 screw) and unplug the unit. There should be 4 bolts/screws holding the gauges on. That's all there is to it.
Title: Re: Odometer
Post by: Justdirt on July 10, 2014, 10:02:57 PM
Many Thanks, I am heading into the garage to begin removal.  Have a great Weekend.
Title: Re: Odometer
Post by: Justdirt on July 10, 2014, 10:46:05 PM
Removal of Instrument Cluster completed.  Thank you very much for your assistance. :bmwsmile
