TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: grant71 on June 08, 2014, 06:56:32 AM
Title: FUEL LEVEL
Post by: grant71 on June 08, 2014, 06:56:32 AM
A while ago i replaced my fuel level apparatus on my 86 K100. Since then the dash light goes on prematurely say when the tank is 3/4 full. i need to bend the ball arm but i dont know which way. Could someone advise me please.  tks
Title: Re: FUEL LEVEL
Post by: rbm on June 08, 2014, 07:31:57 AM
Don't do that! The reserve level threshold is adjustable on the sender. It can determine when the lower wiper contacts the plate.
(https://lh5.googleusercontent.com/-zZmaqUZpLuI/UjoemQONEkI/AAAAAAAACzo/BvP_uA1zoiw/s640/DSC_0035.jpg)
In the photo above, you can see a toothed wheel.  This wheel rotates on a nylon pivot, causing the bottom plate to be rotated and the contact to change position.  Using a small screwdriver, get a purchase on either of the indicated lever points and engage the tip of the screwdriver's blade with one of the teeth of the wheel.  Rotate the wheel with a levering action.
