MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: pfalk on June 02, 2014, 07:43:30 PM
-38,000 miles, non ABS
-new as of june 2012: splines checked and relubed, coolant replaced, brake fluid throughout, brake pads (front pads and rear shoes), plugs, fuel pump and sundry items in August 2013, inside of gas tank professionally cleaned and is spotless August 2013,
entire running gear checked by certified BMW mechanic, new BMW fuel lines May 2013
-compression at factory spec across all 3 cylinders
-Does not burn oil
-Piaa driving lights
-extra LED brake light
-newer Bridgestone Spitfire 11F tires (one season)
-regular seasonal oil changes with BMW OEM parts and oil
-Heated grips
-BMW city paniers
-Aftermarket removable windscreen
-Aftermarket rear fully adjustable shock
Turn key and go. Great for city riding, weekend cruise, or long trips. Daily driver, stored under cover. Turns heads, not many of these for sale, especially with this low milage.
Needs new seat as current stock seat as temporary, but fully functional waterproof, cover. Foam is still in great shape, so could just use a recover if you wanted to keep it stock.
$3500 as is, or $4000 if you want me to put a new seat on.
**Located in Victoria British Columbia Canada**
email paulfalkiewicz@yahoo.com
http://www.usedvictoria.com/classified-ad/1986-BMW-K75_22250756 (http://www.usedvictoria.com/classified-ad/1986-BMW-K75_22250756)
Cheers :)
