TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: CRASH on May 11, 2014, 01:19:20 AM
Title: Dreaded Rear Main Seal
Post by: CRASH on May 11, 2014, 01:19:20 AM
Working on a friends 04 GT
You have probably heard about the Dreaded Rear Mail Seal Failure.
First you will see something like this around the seam between the engine and trans.
(http://i1081.photobucket.com/albums/j346/Gulgamesh/Rear%20Main%20Seal/DSCN03371_zpsbad516bb.jpg)
You will start to have clutch slippage (not power loss  ) ... the engine will rev, but you will accelerate very slowly if at all.
That means you have to do something like this
(http://i1081.photobucket.com/albums/j346/Gulgamesh/Rear%20Main%20Seal/DSCN03361_zpsac7ee4f2.jpg)
And when you take it apart you find stuff like this
(http://i1081.photobucket.com/albums/j346/Gulgamesh/Rear%20Main%20Seal/DSCN03401_zps05491719.jpg)
(http://i1081.photobucket.com/albums/j346/Gulgamesh/Rear%20Main%20Seal/DSCN03391_zps9a5a71be.jpg)
(http://i1081.photobucket.com/albums/j346/Gulgamesh/Rear%20Main%20Seal/DSCN03381_zps33357dde.jpg)
At this point, it is probably a good idea to have the trans seals checked and replaced as well, if you have gone in this far, you may as well. Replace the main seal, o-ring, any hard parts as required (on this one they are fine) any bolts inside the bell housing (pressure plate bolts primarily).
Whoo hooo - and I said I was done with BMW clutch jobs after I did Pongo's Blue RT.
Title: Re: Dreaded Rear Main Seal
Post by: Glacial on May 11, 2014, 06:06:27 AM
Can't see your images ..... :dunno2:
Post by: CRASH on May 11, 2014, 09:50:39 AM
Odd.  Put them on a different service, can you see them now?
Post by: johnny on May 11, 2014, 10:04:49 AM
lotts o goo that pawprint was leaking... it wasnt gonna be long before she was gonna call you for a trailer fetch...
Post by: CRASH on May 11, 2014, 10:25:06 AM
As soon as I loosened up the trans and pulled it back, about 1/4 of a quart of oil poured out.  But it smells odd and is pretty gooey.  Not sure if it is motor oil or trans oil - doesn't feel or smell like either ... and I have not had a chance to taste it  :lets-eat: ... having the trans seals checked out while I have it out.
Post by: Glacial on May 11, 2014, 02:07:19 PM
[/quote]
Yes, horribly clear now - what a mess!
Post by: K75RT Keith on May 11, 2014, 10:06:35 PM
I agree with your analysis.  Replace it all from the rear seal to the trans seals.  While it's apart I'd suggest you check the bearings in the trans and the spacer bushings on the upper trans shaft.  Mine were self destrucitng.
