TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: pauvil on May 10, 2014, 11:41:48 PM
Title: 1994 K 75 stock shock mounting question
Post by: pauvil on May 10, 2014, 11:41:48 PM
My Clymer manual shows the shock mounted with the spring adjustment up by the seat, seems upside down, all the pictures I've seen look this way as well. Does it go this way? Adjustment ring by seat, does it really matter?
Title: Re: 1994 K 75 stock shock mounting question
Post by: K75RT Keith on May 11, 2014, 12:38:35 AM
Doesn't matter much on the stock shock.  doesn't seem affect the life of the shock or how it works.  I upgraded to a YSS and was advised to put the adjusting ring on the bottom.
Post by: TimTyler on May 11, 2014, 01:55:42 AM
It depends on the shock.
I know the least expensive Progressive shock can be improperly mounted upside down.
Quote
From the Progressive 412 Series BMW K Bike Single Shock Installation sheet:
" 2. Install the Progressive Suspension "K" Bike shock (shock shaft facing up) with a supplied washer on each side of the bushings on both the top and lower mounts." (http://www.bmwmoa.org/forum/showthread.php?57450-93-K75S-Replacement-Shock-Options&p=802824&viewfull=1#post802824)
