TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Zipster on May 06, 2014, 02:00:35 PM
Title: Master Cylinder Rebuild Kit - K1100 LT
Post by: Zipster on May 06, 2014, 02:00:35 PM
Anyone know where I can get a Rebuild kit for my master cylinder?
After cleaning it up last week it's still leaking a bit of brake fluid although not too much.
They seem to be scarce items as any I've seen are very expensive compared to other manufacturers rebuild kits I've seen.
Title: Re: Master Cylinder Rebuild Kit - K1100 LT
Post by: johnny on May 06, 2014, 06:32:01 PM
http://www.beemerboneyard.com/macyreki.html (http://www.beemerboneyard.com/macyreki.html)
i did my front with one of their kits...
Post by: Zipster on May 06, 2014, 07:07:56 PM
Man, their cheapest shipping to the UK is the same price as the kit but I must say the price of the kit is almost half that of the UK sellers. Anyone in the US want to check out postal rates to the UK?
Low and slow to BT74 4QS please. If it beats $46 then maybe we can come to an arrangement?
Thanks in advance. Al
Post by: Elipten on May 06, 2014, 11:08:00 PM
Zipster, ask if anyone is going to the UK and can carry for you.  I just shipped some parts to South Africa for a fellow member and they weighted nothing but the shipping cost was shocking.  So given that experience it may not be as cheap as you think.
I am off to Peru for work but if you get the weight and no one helps by the time I return. I'll find out for you.
Post by: johnny on May 07, 2014, 12:33:58 AM
peru is known for its goat weed butter...
Post by: Zipster on May 07, 2014, 12:18:51 PM
I know it weighs very little as I've had the master cylinder apart. Probably about 50 grams or less than 2 oz (US) so thanks for the offer. Much appreciated.
Post by: Zipster on May 07, 2014, 03:47:29 PM
Will this fit onto a K1100LT?
http://www.ebay.co.uk/itm/141168213279
Post by: mystic red on May 07, 2014, 04:17:08 PM
Nope....at least it's a different part #.
Post by: Inge K. on May 07, 2014, 05:58:53 PM
It's for a 2V model....which got a smaller bore/piston........2V, 13mm....4V, 20mm.
Post by: drut on May 07, 2014, 06:29:24 PM
AFAIK your master cylinder will be a magura 20mm http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=40&Ct=IA&SbCt=BA_15_40_IA_40 (http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=40&Ct=IA&SbCt=BA_15_40_IA_40) .I bought one at the end of August last year,after seal kit did not work owing to worn/pitted bore,was upset that cost was £144 + postage but note present price is £229.46 + postage!!!!!
Post by: Zipster on May 07, 2014, 07:31:00 PM
I checked out the USPS website and not only did I get the $46 postage priority mail but I also got the option for a first class international large envelope instead of the priority mail option. It came in at under $10 and under $9 if bought online!!
Post by: Elipten on May 07, 2014, 10:57:00 PM
Ask the boneyard if they can ship using the lower rate.  Maybe they did not do any homework.  Man a 85 GBP increase in less than a year is a shock.
Post by: johnny on May 07, 2014, 11:23:56 PM
usps small flat rate box to gb...
i would do this for you butts im traveling for work and do not have a reliable shipping address... butts... you cold ask for a usa to score it and have bby send it to their usa address... then they can send it to you by the united states postal service... i would ask bby to send it usps 1st...
click here... (http://ircalc.usps.gov/MailServices.aspx?country=10143&m=6&p=1&o=0&MailingDate=5/21/2014&MailingTime=8:00%20AM&dv=50.00)
Priority Mail International® Small Flat Rate Box**More info about Priority Mail International® Small Flat Rate Box** Value of contents can not exceed $400.00 USPS-Produced Box: 8-5/8" x 5-3/8" x 1-5/8" Maximum weight 4 pounds. 6 - 10 business days $24.75
usps first class package to gb...
First-Class Package International Service™**More info about First-Class Package International Service™**
Value of contents can not exceed $400.00 Other than rolls: Max. length 24", max length, height and depth (thickness) combined 36" Rolls: Max. length 36". Max length and twice the diameter combined 42" $16.75
Post by: Zipster on May 08, 2014, 04:16:48 AM
Thanks guys. I've a couple of friends in Indiana are gonna help out. Much appreciated.
Post by: Elipten on May 08, 2014, 09:51:32 AM
Glad you found a reasonable solution
