TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: drut on April 26, 2014, 03:40:10 PM
Title: K100RS 16v rear shock question
Post by: drut on April 26, 2014, 03:40:10 PM
The rear shock on my 1990 K100RS 16v(30.000ml) is non adjustable and seems adequate at best,a good friend has offered me an adjustable damping shock from a similar mileage 1993 K1100LT for next to nothing.Question is would it offer any improvement:present shock is Bilstein,K1100 shock is Showa.Provided I keep power on & corner smoothly I can manage OK with present shock and it does not leak but ripples/bumps upset the rear of bike whilst front end still feels "planted".
Title: Re: K100RS 16v rear shock question
Post by: johnny on April 26, 2014, 09:02:34 PM
greetings drut...
seeing you are in the uk... i would go with a  realm ram (http://www.realmengineering.com/page15.html) and be done with f-ing around...
Post by: drut on April 27, 2014, 05:27:16 AM
greetings drut...
Yep I think you are right I've heard they are good.I'll give them a phone:the link you gave(thanks!)has a 2005 date at bottom & shows a tax rate of 15% when it has been 20% for a while so I hope they are still available
Post by: subforry on April 27, 2014, 07:35:30 PM
The Showa is not rebuildable.  The Bilstein might be.  My guess is that both are dead.  If you want to spend as little as possible, then ask a shop about rebuilding the Bilstein.  Best option is get an after market shock.  There are plenty recommendations here on the forum.
Post by: tg4360 on April 28, 2014, 12:45:32 PM
Also the K1100 shocks may be longer than the 100 shock if your bike is not new enough to have the paralever.
I've put one on my LT as I wanted/needed more ground clearance.
Post by: drut on April 28, 2014, 06:54:26 PM
AFAIK K1100 has same shock length(380mm ?) as K100 16v which as you have pointed out is also paralever,thanks for the input!From what I have gathered up to now:there are no good original shocks & I should look to best aftermarket.
Post by: Brad-Man on April 28, 2014, 07:35:30 PM
IMHO the RAM shock seems to be best for the money and is what I will put on when I get around to going to the paralever rear end I have waiting...
