TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: grant71 on April 22, 2014, 02:29:34 PM
hello everybody. my horn snapped off the steel fairing frame. i am going to have it welded. now besides disconnecting the battery, is there any other precaution that must be taken? tks
Alternator, injection ECU and ignition ECU.
And to be on the safe side also disconnect instruments, heat management relay and flasher relay.
how do i disconnect? remove fuses? remove relays ?
Pull connectors from the alternator and the computer stuff like Injection ECU, ignition ECU, instruments. Pull the relays from the sockets.
if it was my horn i would velcro it on there and leash it with a fishing line leader...
When I worked in a car bodyshop they used a surge protector http://www.goodallmfg.com/antizap-surge-protection/ (http://www.goodallmfg.com/antizap-surge-protection/) when mig welding with no problems.However if I was welding my bike I would unplug ecu & disconnect battery earth,a good clean earth point as close as possible to the weld area would also be wise.
Why not take the bracket off and weld it off the bike?
For record when I'm welding on my cars I take the cables off the battery and tie the ground to the positive to make everything electrically common. Don't know if that's 100% right but haven't had a problem yet.
