TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Zampano on April 15, 2014, 07:33:15 PM
Title: a few, likely moronic (*not motronic - ha i'm an idiot), questions..
Post by: Zampano on April 15, 2014, 07:33:15 PM
First, the dumb question... Is this a stock shock?? If it is I believe it is not installed upside down. I don't see any markings but it does look somewhat like the shock shown in my haynes manual. The more I've investigated this "impulse purchase" the more it seems reassembled from lord knows what by very amateur mechanics (LA trust fund kids).
while I have you..
1. how do you know how "bad" your shock is. This is my first bike ('92 K75S) and i've spent most of what little extra ducats I have in trying to correct/improve how the bike runs. I've totally ignored suspension and cosmetics. The bike rides a little rough i believe. I'm also in OB, san diego; where the roads resemble beirut in the 80s. A KTM adventure R is recommended.
2. In trying to solve the "underpowered" and inconsistent running/idling I will be replacing fuel filter, air filter, checking for any vacuum leaks (crankcase hose already replaced), and sending the injectors off to mr injector (although I guess there is really no way of knowing if they are "bad" or just need new seals. But since i've owned the bike for almost 2 yrs and don't trust previous owners i feel it's worth the $60). I did spray brake parts cleaner while running and one/two of the injectors seemed to be a culprit.
3. I have some noise from the timing chain. Bike was at dealer for a valve check, throttle body check (they were fine, but I was not spared the dealer raping my bank card). Dealer thought it was likely guides. Also told me everything and its brother was leaking and needed replacing. That was a year ago and i'm still rolling. However, down the road i would like to address the front and rear of the engine. Those are bigger projects and I am procrastinating. Bike will likely break down the day i take it to baja, so i'll post pics from my mexican jail cell. My question is could rattling timing chain affect how the engine runs? I think it's a possibity but not sure.
4. I could use a L front fairing and/or blinker lens if anyone is selling. I would also considered replacing the entire front fairing with a smaller C style.
5. Seat is a corbin but torn and feels like zero padding (although i hear they are firm to begin with). Has anyone taken the "$60 airhawk pad" route instead of paying $250+ to refurbish/replace seat?
5. If anyone knows of independent mechanic worth calling, please let me know. I'm relatively capable but do not have a garage or many tools. If there is someone who I could pay to assist where I possibly take bike down and do the b.s. work of putting it back together that would be ideal. Just pay them for their expertise and time.
thanks a lot. enjoy the summer. keep hyperaware on the roads. replete with loons.
Title: Re: a few, likely moronic, questions..
Post by: mystic red on April 15, 2014, 08:40:54 PM
Been so long since I've had a stock shock but that looks like an upside down stocker. Get yourself a good aftermarket a don't look back.
Mr. Injector will send you a report card with your clean injectors.
Don't worry about the timing chain noise.
Don't listen to a dealer.
Post by: Chaos on April 15, 2014, 10:03:10 PM
Sounds like you're on the right track.  Like to know the logic behind the upsidedown stock shock?  Those things are shot after 20k miles ever right side up. Might be worthwhile to check the valves (easy) just to be safe.  Plugs and wires could be suspect if keeps running badly.
Post by: roninvt on April 15, 2014, 10:47:27 PM
When I got my K75C the stock shocker was installed just like the one in Zampano's pic.  I do not believe it is upside down.
Post by: K75RT Keith on April 15, 2014, 11:18:49 PM
Zampano, Welcome to the wonderful world of K-bikes.
Shock is mounted upside down.  Might want to flip it over.  It was likely installed that way to get to the adjuster.  Right side up it's tougher to get to.  If the seals are gone, so will be the hydraulic oil.  Most manufacturers advise against installing upside down.  YSS make a pretty good replacement at a fair price.
You can tell when it is shot when it continues to bounce after the the road smooths out.
Don't forget the sock filter on the end of the fuel pump.   Check that the rubber bits in the tank haven't turned to goo.
Timing chain noise is not a serious issue. gaskets for all the covers and the bolts aren't that expensive and could be changed in an afternoon
Splines are not something to be ignored.  Lack of care gets real expensive real fast
Corbins are very hard and the one I bought didn't soften up even after 5000 miles.  My buddy tried the Airhawk on his R1200RT and ended up buying a different seat.  Keep an eye on Fleabay, craigslist and sites like this one for a deal.
Someone here might be of assistance.  Also check this site, there are names of independent wrenches that may save your wallet a beating.
Once you sort out the "underpowered" issue, it will run for a long time.   FWIW the power curve on a K starts around 3500 rpm.  They like rpm's and don't like their clutches slipped (an expensive mistake if you do)
Take a tour of the Liberry, theres lots of useful information
Post by: Inge K. on April 16, 2014, 04:06:51 AM
Shock is correct mounted, here is a picture from a -92 sales brochure:
Post by: Zampano on April 16, 2014, 04:45:57 AM
thanks for the replies. You guys are the aces.
- I did have valves checked at stealer. Told they were fine.
- The shock doesn't seem to "bounce" or appear to be leaking. If anything it feels a little stiff. Either way it's too soon for me to grab another. Other concerns more pressing. Unless I stumble on a deal. I believe it is mounted that way because of the haynes manual that came with the bike. The book states it is installed with the preload collar "up" and there is a pic in the book showing it that way. I'll attach.
the plan:
- pull the driveshaft and inspect & re-lube the splines this weekend. Clutch splines will need to wait. It appears straightforward and I need to bring the rear wheel in to have a new tire mounted anyways. I have guard dog moly bought from beemer boneyard.
- change gear oil in the final drive and transmission. also quick and $25. mobil 1 synthetic 75/90 or should i go get the dealer stuff? i also saw 140/90 (?) mentioned.
- mr injector / fuel filter / air filter  Bought the fine autrian mahle brand. I'll look for tiny black bits in tank. Don't see any now but i'll get a better luck when i change filter.
- oil change for good measure. I hope this isn't stupid but I purchased mobil 1 synthetic 15-W50 at wal mart b/c it was $25 for the 5 qt jug. However.. it is motor oil.. not motorcycle oil. From what I read it is ok b/c of the dry clutch. Is that correct or did i just throw $25 down the crapper? It's the green top too. Did not have the "red top" (whatever that means. higher mileage?)
then, continue to beat the hell out of it... (except for the shifting part)
I rode home at 70-75 on a nice highway today and it felt pretty good. Except for the wind. I have nothing to compare it to except an R1 I learned to ride on a dozen years ago (yeah, i know). Also a new tire may make the bike feel totally different.
thanks again for the input. I think the bike has potential. Not much to look at but if I can get it running proper that is fine by me. If it takes me and a tent to the beach in baja (*and back) i'll consider that a victory.
Post by: Zampano on April 16, 2014, 04:51:10 AM
thanks. That looks a lot like my bike, before 22 years took their toll.
the wonders of android camera effects make it look quasi-respectable.
Post by: Zampano on April 16, 2014, 05:34:49 AM
bear in mind i am a dummy...  and this is my first bike. By slipped do you mean the "half clutch" maneuver? Or the old power shift sans clutch in the old 70s muscle cars. I read that a full clutch pull is sometimes worse than a 3/4. It seems a little bit of an art to find the happy shift. Especially 1st to 2nd. I've tried a little preload on the shift lever and not quite a full clutch pull. Bike appears to like that and at times shifts like butter. My thought is the smoother / quieter the shift the better. It also likes to shift 1st to 2nd when the choke is on. Which essentially tells me to keep a little more throttle.
Post by: Motorhobo on April 16, 2014, 05:57:14 AM
Quote
There's some info here -- pdg did a pretty good job DIYing his seat if the photos are any indication.
http://www.motobrick.com/index.php?topic=3713.0 (http://www.motobrick.com/index.php?topic=3713.0)
If you're doing to DIY it, why not put a gel-pad in there? My ass wishes it had one.
http://www.saddlemen.com/products/k2mart/saddlegel-pads/do-it-yourself-raw-gel.html (http://www.saddlemen.com/products/k2mart/saddlegel-pads/do-it-yourself-raw-gel.html)
Quote
Or if it doesn't do jacks**t. My old one wasn't was frozen up and the bike rode like a hardtail -- felt like it was bottoming out at every bump.
Quote
Take a look at the Parabellum Scout -- http://parabellum.com/. (http://parabellum.com/.) There's also a motobrick thread on aftermarket fairing options here: http://www.motobrick.com/index.php?topic=258.0. (http://www.motobrick.com/index.php?topic=258.0.) I have a couple of pics of the Parabellum Scout and Sport on that thread but they're crappy pics and don't do the Scout justice. The Scout gives good chest and head protection while allowing airflow over your legs, thus avoiding the 'toaster' effect you get from the fully-faired bricks.
Post by: Zampano on April 16, 2014, 01:42:44 PM
The parabellum are nice. Have a good look. I would need to find a C style piece to cover the radiator and a new headlight (mine is square.) Do you know if I would also need to find turn signals? Not exactly certain what it comes with. Either way I'm putting cart before the horse a bit. Should be looking for a nice job instead of researching fairings and shocks and seats. Or not.
thanks again for the info.
also, what I foolish in getting regular mobil 1 synthetic 15-W50 (*not motorcycle oil)? Also planning on using the mobile 1 75/90 gear oil in transmission and final drive.
Post by: mystic red on April 16, 2014, 02:00:02 PM
Quote
That's a fine choice...
Post by: K75RT Keith on April 16, 2014, 02:26:24 PM
I stand corrected on the shock mount.
The K bike motor is the closest thing to a car motor.  so not to start an oil thread I'll simply say Mobil1 s a good choice.
There are quite a few replacement windscreen options for the S model. Best choice is what you're happy with.
Post by: Motorhobo on April 16, 2014, 08:21:09 PM
Sorry -- Parabellum is for the straight K with round headlight -- don't know if there's an S option. Ain't cheap either...and people who have them don't tend to sell them so next to impossible to find a used one.
Post by: johnny on April 16, 2014, 09:05:37 PM
aeroflow has one... (http://www.aeroflowscreens.com/K75S/K75S.htm)
brickus turkus has one of these... i donts know if he has tried it yet...
Post by: K75RT Keith on April 17, 2014, 10:52:02 AM
K75S windscreen from Parabellum and Aeroflow (through A&S).  Due to the high loads on the K75S windshield,(sticker from BMW says don't exceed 98mph) the 4 plastic bolts should be replaced with new every couple years.  Or, through bolt with the likes of plastic license plate screws and bolts.
http://parabellum.com/K75S-Windshield-System-P5.aspx (http://parabellum.com/K75S-Windshield-System-P5.aspx)
http://www.ascycles.com/detail.aspx?ID=2174 (http://www.ascycles.com/detail.aspx?ID=2174)
Title: Re: a few, likely motronic, questions..
Post by: Zampano on April 17, 2014, 08:03:10 PM
thanks. I need to live with mine for the time being. There's a crack in the front left fairing and i believe the headlight fairing surround (whatever that's called). The main bold behind the turn signal is fine but where the headlight fairing piece connects to the front fairing piece there is a crack and it's not secure. Very very frustrating. I guess i will eventually need to take it all down and rig something up. For now it is a few plastic strategically placed wire ties and some small pieces of foam padding.
I do have an issue. I replaced fuel filter/air filter (and got a new tire thank the gods). I noticed the rubber surrounding the fuel pump has indeed become mushy. There are a few tiny black specks that i tried to get out of there but obviously it's becoming a potential fuel pump disaster.
What is my best way to address this? i'll be searching the forum later (too exhausted now). Is the rubber replaceable? Will my fuel pump be crapping out soon? I did not remove the pump and inspect it. Thought messing with the rubber might cause it to disintegrate.
thanks.
Title: Re: a few, likely moronic (*not motronic - ha i'm an idiot), questions..
Post by: Elipten on April 17, 2014, 08:24:56 PM
Go to beemerboneyard and order replacement rubber support and the filter screen on bottom of pump.  Also replace all hoses in there with the type that can withstand submersion in today's terrible gasoline.  Drain gas, remove gas cap (consider rebuilding or cleaning see video YouTube by Chris Harris) remove, clean tank, check for corsion, and replace.
Post by: Zampano on April 17, 2014, 11:30:33 PM
thanks.
Mine is a '92. I'm getting some very mild "stuttering" but seems to be when bike is cold. Could that mean my fuel pump is on it's way out? Should I not ride at all? The tank is extremely clean inside. A few specks, but I think i caused them by touching the rubber. I've checked tank previously and it had always looked perfectly clean inside. I can tell it has been painted and am wondering if it came from a different year. Could that mean I have a different year pump in there? That would mean I need to order different damper. hmmm   :dunno2:
It looks like the damper itself (http://www.beemerboneyard.com/16121464628n.html (http://www.beemerboneyard.com/16121464628n.html)) is $75 so the best option is probably the $92 "kit" (http://www.beemerboneyard.com/16121464628nkl.html (http://www.beemerboneyard.com/16121464628nkl.html)).
The hoses to the pump and filter look relatively new. Feel like good quality stuff. I'll check if there are markings and maybe I can search online to tell if they are proper. I have to save $$ where i can. This bike wil nickle and dime me to death. In the end I maybe could have bought a used GS for $20 more ;]  :euro
emoticon hell.  :falldown:
Post by: Motorhobo on April 18, 2014, 06:32:50 AM
If the pump is running erratically, maybe you just ned to clean the connector under the tank. Bad contacts make for all sorts of probs...Plus don't even cost a nickel or dime to fix. Maybe test the pump on the bench...
If it is the pump you  might consider just replacing the pump with the Ford one -- I think it's for the Ranger or Escort...can't remember, I think it's documented on http://www.ibmwr.org (http://www.ibmwr.org) and might even be here in the Lieberry. I've had a Ford pump in mine for 25k miles. You can replace the pump for less than you'd pay for that tuneup kit from Beemer boneyard. It's an easy mod, if I remember correctly -- I was a total noob (still am) when I did it and was amazed that I got it to work.
Euromotoelectrics.com has the pump kit and the fuel strainer -- http://www.euromotoelectrics.com/BMW-K-R-Fuel-Strainer-Sock-16-14-1-341-233-p/ff-233.htm. (http://www.euromotoelectrics.com/BMW-K-R-Fuel-Strainer-Sock-16-14-1-341-233-p/ff-233.htm.) They also hAve a lot of other K75 goodies, in some cases cheaper and wider selection than Beemer boneyard.
Either nickel and dime or payments on brand new bike with warranty -- no free lunch. But at least with the K bike you know once you've spent the nickel and dime the thing will give you +100k miles.
Van
Post by: Motorhobo on April 18, 2014, 04:44:40 PM
Well -- here's my understanding which is tempered by my relative inexperience in the matter compared to some of the folks on this forum.
The K75 clutch, being a dry clutch, is to be treated just like the clutch of a car. In other words, it should be either all the way engaged or all the way disengaged, I.e. lever all the way out and hand completely off or lever all the way in. Just like the clutch pedal of a car -- you should never ride it with the foot, but always get your foot completely off when not engaged. This stands in contrast to a wet MC clutch which, being bathed on oil, doesn't care whether its being ridden or not.
For me, having burnt thru clutches to the tune of over $1200 early in my Kbike career, that means hand off the lever unless I'm shifting or idling at a stop, in which case the lever is fully in. I find that the k75 is so smooth in first gear that I rarely need to feather or slip the clutch (by that I mean hold the clutch lever halfway between in and out while giving throttle) to do any maneuvering. I can do tight u-turns at walking speed in 1st with my hand completely off the lever, which is something I would have needed to feather the clutch for on my old Honda 550/4.
Now, having said that, most of the time when shifting thru gears to get up to speed quickly, I speed-match the rpms and barely use the clutch at all to shift. But -- once I've reached target speed, my hand is off the lever completely. Basically, my understanding is that your K clutch needs to be adjusted with the proper amount of free play. If you ride with your hand on the lever with enough pressure to bring the lever within that free play region, you're burning up your clutch and helping it to a premature death.
So, my riding style is based on the above credo because that's what I learned from my old-school Beemer mechanic buddies back in the 2000s. If I misunderstood what they were telling me, somebody please tell me now!
Quote
This bike will nickel and dime me to death
I would caution you against spending any money unless you know what you're spending it on -- you can go broke real fast that way. For instance, I've never done anything to the fuel system except replace the pump because it failed completely. if you're missing or stuttering, there are a number of things that could be that have nothing to do with the tank. A most likely candidate for missing is the spark plug cables which fail after time. I replaced them all with OEMs T least once in 14 years ($280!) and recently replaced one of them again with the aftermarket silicon ones ($80 for set of three)  from Beemer boneyard. If it is a spark plug cable, it will get worse, then you'll know to replace it. In the meantime, park the bike outside, take the spark plug cover off, wait till it gets dark, throw a blanket over the headlight, and look at the plugs to see if the spark is arcing off any of the cables. If it is, then the spark isn't getting to the plug so the cylinder isn't firing. It gets worse over time...at some point you're running on two cylinders and you know you have a problem and where to look for it.
The choke isn't really a choke -- all it does is add some throttle to increase the idle RPMs so it doesn't stall out when idling cold. Not sure how that could affect shifting...Have you done the FD and DS splines yet? That should really help with the butteriness of the shifting.
I'm always reminded of Johnny's words of great wisdom... More motobrickng and less hand-wringing, or something to at effect. Johnny's philosophy is make sure your AAA is paid and ride it. When something is wrong with it, it will let you know and 99.9% of the time it will get you home safely first.
My humble $0.02...
Van
Post by: Zampano on April 18, 2014, 09:08:54 PM
thanks for your thoughts. I agree. The way my existence has been going "nickel and diming" refers literally to nickels and dimes.  Most of the dough I dumped was necessary. Tires, brake pads, battery, starter brushes/relay. Since I don't trust the folks I bought it from (and it's been almost 2 years) I decided to change the air filter/fuel filter. The engine runs ok, but I can tell by how these bikes are thought of that something is amiss. It is hard to put into words but you know the sound of an engine that is hummin'. Mine isn't there. It will hopefully turn out to be something simple. Just a matter of addressing everything in a logical manner. I don't want to jinx myself but I think the injectors & fuel pump/filter are the culprits. Hopefully not the regulator, but I'm not sure what symptoms a bad regulator cause. Part of the reason I took it to the dealer was I thought they would have an actual mechanic there who could ride a bike and rule in or rule out various things. No such luck. They only do what you pay for. Shocking considering small issues on bikes can be life/death.
Quote from: Motorhobo
This is interesting. On my bike in first gear the throttle response is so jerky that it is an adventure in parking lots. The throttle mechanism moves smoothly. However in 1st, you don't know what you're going to get when you advance the throttle a millimeter or two. It could pull forward instantly with X amount of power or maybe a few milliseconds later with a little more or less than X. On a motorcycle this is dangerous b/c everything is feel/balance. You need to know what amount of power you will get with each subtle movement. Above 15 mph you're fine and will never know the difference. But slow speed riding is not right. Now that I'm thinking about it, I wonder if my problem lies in the pressure regulator. I'm not spending another dime right now.
After taking out the fuel pump and injectors they both need obvious help. 40% of that damper is "gone." I'm hoping it will fire up and run proper afterwards.
My plan is to do the final drive splines this weekend. I'm still not 100% sure if I should pull the driveshaft and do both ends or just the rear. Knowing myself I'll give it whack and pull it. I have not come close to the clutch splines. That's a bigger project and I live in an apt with minimal tools (i.e., on the street.) A year ago the dealer told me the rear seal was leaking, so i figured eventually that will start "really" leaking and hopefully before it does i'll find an independent mechanic or someone I can pay (in $$ and/beer) to tear it down and address whatever needs to be addressed in there.
Agreed!!
Post by: Elipten on April 18, 2014, 09:32:50 PM
The Kbike does not nickel or dime, it eats $50 and $100 quickly.  But once sorted and you learn a few things and wrench yourself; it can out last you!
