TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: JVDH on April 02, 2014, 11:15:44 PM
Title: Front right blinker not working on a 93 k1100rs, not bulb
Post by: JVDH on April 02, 2014, 11:15:44 PM
Hi all,
I recently acquired a 93 k1100rs.  The front right blinker isn't working, I tried changing the bulb but that wasn't the issue, as it is still not working. I have been searching the internet but haven't found a solution to this problem.  Do any of you have any insight into this, what do you think I should check next (fuse, relay, wiring?)  Thanks in advance for your help!
Title: Re: Front right blinker not working on a 93 k1100rs, not bulb
Post by: Inge K. on April 03, 2014, 02:09:23 AM
Check wiring, and the connector between the fairing and mirror.
Post by: JVDH on April 03, 2014, 11:41:19 AM
Thanks Inge K., will try that next.
Post by: JVDH on April 20, 2016, 01:39:35 PM
...follow up regarding the blinker issue, the issue was that the wiring was disconnected between the mirror and the fairing.
