TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Brickhead on June 01, 2011, 04:46:52 AM
Title: mushy handle bars
Post by: Brickhead on June 01, 2011, 04:46:52 AM
I am confused about the number 3 washer. Does this go inside the rubber bushing or sit on top of the bushing with a hole large enough for the mount to pass through? I would think that the cone shape under the mount would fit through the washer three. Yes, no?
I ordered washer three from Touring Sports in NC and what I received is not large enough in the ID to have the mount shaft pass through.
Title: Re: mushy handle bars
Post by: gladstone on June 05, 2011, 04:27:50 PM
I have two LTs - one had the washers and one didn't.  Where it was present it was large enough to fit outside the metal inner.
Cheers
Post by: johnny on June 05, 2011, 04:44:58 PM
greetings brickhead...
on the bug... a 94 k1100 rs... 3 sits on top of the bushing with a hole large enough for the mount to pass through...
Post by: Brickhead on June 05, 2011, 08:20:11 PM
Well that is what I figured but when BMW sent me the washer it was only big enough to go over the threads of the mount. Obviously the fiche is all screwed up.
There is confussion on my part because I reada thread that the washer goes below the mount where the nut is and others that say it goes on top.
I have made a washer large enough to allow the conical part of the mount pass through. I couldn't find one in the hardware store big enough so I had to make one out of an electrical box cover of which the breakout tab hole is a perfect fit. It is quite a stout piece of metal also
