TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: roninvt on February 22, 2014, 05:21:19 PM
Hi...I have a 1990 K75. Last year I installed an eastern beaver headlight relay kit. Today I installed a pair of Denali D2s as per the instructions. These are dual intensity lights, low beam is fine, but no high beam. I posi-tapped into the white hi-beam wire under the tank. Are the eastern beaver and denali relays messing with each other? I am thinking about tapping into my hi-beam wire between the headlight and the beaver relay. Any thoughts...
If you tapped the same hi-beam wire for both relay setups I'd suspect a problem with your Denali relay.
Did you remove the EB relay's? If not, do they still work right?
Hi Scott, The EB is working fine, I have hi and low beam on headlight. Only low beam on Denali. It does sound like their relay may be faulty. Thanks
