TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: MCrenshaw on February 04, 2014, 03:19:28 PM
Hi, last week I took possession of a '94 K1100RS. I had the chin cowl off to inspect the spark plugs, and noticed a missing bolt or screw on the right front corner of the oil pan. The bolt hole comes in from the right side, not the bottom. I can't imagine this being like this from the factory so I presume that the bolt/screw is missing. A look at the microfiche does not show this bolt because it is on the right side; the diagram only shows the front and left sides. Any suggestions if this is a special bolt? -Mike
Is it the one in the picture you have in mind? If so, it's used for mounting crash bars and engine spoiler
bracket, when not in use a plastic plug covers the hole.
i remove my plastic plug covers to shed weight... then i raise my ride height... then i can lean more before i scrape peg...
Yep, that's the one. I like your idea of weight savings. I could probably save a few miligrams if I were to plug it with a twig instead of a steel bolt. Thanks for the quick reply! -Mike
When I worked on the Berkeley formula racing team, they had me machining bolts on a lathe to remove a thread or two to save weight.
