TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Liverpool Brick on January 27, 2014, 10:28:25 AM
Hi,
Carried out routine filters, plugs and oil service on my '91 K75S and whilst the filter box was apart I checked the crankcase breather hose which turned out to be split. Fitted a new one and yeeeeehaaaa! Its a new bike! So, my advice is check that hose and fit a new one if needs be. Its an easy, cheap repair and the benefit is that much joy abounds.
Keep 'er lit,
Andy
Hi Liverpool, I just picked up a neglected K75. it was left out in the weather, i would say most of it's life. Its a '94. Anyway my question is did you se an improvement in engine operation after fitting new breather? This bike starts easily but is finicky on idle. Acceleration produces skipping and backfiring. I replaced the breather and vacuum nipples (they were cracked as well). I think there is a slight improvement in the running, bit still far from right.
Just looking to see if an air leak might be the problem...
Thanks!
Start the bike and use an unlit propane torch around the throttle bodies and rubber mounts and watch for increased idle rpm. Increase in idle speed indicates a need for new throttle body rubber mounts(?) These bikes are very finicky over tiny vacuum leaks.
+1 on throttle bodies hoses. I had to rebuild mine because of micro cracks probably due to weather exposure and some overheating I had because of a bad fan. Runs great now. Btw I didn't know that about the propane torch...I had to wait till the leak was bad enough to hear with a straw in my ear.
I'm sure there's a long thread on the throttle bodies rebuild in here somewhere...there's an issue with the clamps. I think you can only use oetikers on some of them because of space issues. I had to get a tool to do the job.
