TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: keith g on January 16, 2014, 11:28:56 AM
ok........i replaced the fuel pipes from the regulator to the tank and the return,did not disconnect the MAF,just left it hanging,got good pressure from the pump......got sparks.......still won't start.......any ideas welcome......
Try reseating the connector on the computer, then check for voltage at the injectors
I would like to add that voltage is only present at the injectors when you press the starter button..........
or the engine is running.
But as your fuel pump is running you probably also got voltage at the injectors....powered from the same relay.
The signal to the injectors is on the ground side.
ok.....thanks guys i'll look at that today ...cheers :2thumbup:
OK.......between you guys and Frankenduck's repair PDF......i have to confess...i'm an idiot...!!!
i cross connected the fuel pipes........DUHHHHHH!!!!!!!!!!!
