TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: subforry on November 17, 2013, 08:08:29 PM
Title: Runnig light in mirror upgrade with pics
Post by: subforry on November 17, 2013, 08:08:29 PM
I added some dual filament bulbs (1157) to the mirror turn signals on my K1100RS.  I removed the connectors, used a Dremel to bore out the plastic holder to allow for a dual filament base.  The fit was tight enough but I used some thin CA glue.  Then ran wire from the headlight running light to the mirrors.  Uses standard 1157 bulbs.  Here are some pics.
Title: Re: Runnig light in mirror upgrade with pics
Post by: johnny on November 17, 2013, 08:25:59 PM
righteous...
Post by: Scott_ on November 17, 2013, 10:16:37 PM
As you are running those, keep an eye on your plastic lenses for heat discolouration or deformation.
The heat generated from a running light in a space that wasn't designed for a incandescent running light may cause you problems.
I'm not saying that it absolutely will, but just beware that it's a possibility.
You may consider a dual wattage LED lamp, same dual purpose but no heat....
Post by: subforry on November 18, 2013, 02:46:38 PM
Scott_ Thanks for the tip.  Will 1157 led bulbs work with the stock turn signal relay?
