MOTOBRICK.COM => The MBdotCOM Community Center => Topic started by: metriccyclesllc on October 22, 2013, 10:28:51 PM
Title: Updating Side Case Locks
Post by: metriccyclesllc on October 22, 2013, 10:28:51 PM
Does anyone know if it is possible to replace the locks with the goofy little key on the Integral side cases on my K 100 RS with more modern OEM locks with tumblers that could be keyed to my ignition key?
Title: Re: Updating Side Case Locks
Post by: argent brick on October 23, 2013, 02:38:48 AM
It can be done, but it is not cheap to do. It runs about $25 per latch, with three needed per case. I don't remember if that includes the key assembly or not. Each latch is just riveted in place so you can do the install yourself if you have the tools.
Only the 1st generation cases use the small flat keys. Some of us need 1st generation keys so please don't throw them away if you make the swap.
You might get lucky and find someone that has a set of third generation cases for sale. Most riders consider these the best cases that BMW offered for the K bikes.
Second generation cases also use the OEM keys but the locks are turned so that they face the bike. Also, the handles are different on the newer cases.
Post by: metriccyclesllc on November 06, 2013, 08:21:09 PM
Thank you very much.  After reading your suggestion I actually found a very old  BMW tech bulleting outlining what you described.  Have ordered all the parts and tomorrow will ask my mechanics to drill out the existing rivets and install the new hardware.  If all goes well I will spend thousands on this restoration and end up with another bike that will still sell for two grand.  If I didn't work selling BMW bikes, the damages would just be worse.  Again, thanks.
