TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: johnny on September 23, 2013, 08:23:25 PM
Title: Alternative Valve Shims ~ original poster wmax351
Post by: johnny on September 23, 2013, 08:23:25 PM
From the list at IBMWR.org, with a few annotations from me (wmax351).
Yamaha/Kawasaki shims for 2-valve K shims
Date: Tue, 18 Nov 1997 11:04:23 -0700 (MST)
One item did come up I want to let owners know about. If you need a shim for your 2 valve K and you don't have a dealer close by, shims from some models of Yamahas and Kawasakis will fit in the Ks. If you have one of these dealers closer I'd use them. I have many times on my bikes and others. Ciao Tony
Title: Re: Alternative Valve Shims ~ original poster wmax351
Post by: wmax351 on July 06, 2014, 12:52:55 PM
I've found that the 29mm ebay valve shims are slightly larger diameter and don't fit.
http://www.ebay.com/itm/29mm-Diameter-Valve-Shim-Size-2-00-KAWASAKI-YAMAHA-BMW-/161327992391?pt=Motorcycles_Parts_Accessories&hash=item258fe5ce47 (http://www.ebay.com/itm/29mm-Diameter-Valve-Shim-Size-2-00-KAWASAKI-YAMAHA-BMW-/161327992391?pt=Motorcycles_Parts_Accessories&hash=item258fe5ce47)
Post by: Motorhobo on March 11, 2019, 04:35:29 PM
For years I've been using feeler gauges that I pulled out of a set of SAE/metric like this one:
https://www.ebay.com/itm/32-Blade-Feeler-Gauge-Metric-SAE-Dual-Reading-Combination-Gap-Thicknes-Measure/292698803616?hash=item4426354da0:m:mhCmUi9i2x24baZqVCtOmUg&frcectupt=true
I put safety pins through the hole at the end and wrapped ducttape around them to give them some kind of handle. It worked but sucked because the ducttape is slippery and the individual gauges are actually SAE with metric translations, so like this:
.0015/0.04mm, .002/0.05mm, .0025/0.06mm, .0028/0.07mm, .003/0.08mm, .0035/0.09mm, .004/0.10mm, .005/0.13mm, .006/0.15mm, .007/0.18mm, .008/0.20mm, .009/0.23mm, .010/0.25mm, .011/0.28mm, .012/0.30mm, .013/0.33mm, .014/0.35mm, .015/0.38mm, .016/0.40mm
F**king annoying. I just want metric values in round numbers, I don't want to have to do any extra goddam math. So I got these from http://www.Tills.de.
https://www.tills.de/0-15-mm-fuehlerlehre-satz-fuer-bmw-r850gs-r1100gs-r1150gs-r1200gs-ventillehre-inspektion-312-314-318-319.html
Pro tools in a nice little container for $10. Can't beat that.
Post by: stokester on March 11, 2019, 06:03:40 PM
They look like the Wurth feeler gauges I got for my Airheads from Beemerboneyard for just the same reason.
https://www.beemerboneyard.com/wurthairhead.html (https://www.beemerboneyard.com/wurthairhead.html)
I like them and will probably order a set from till.de, they have some good stuff for us.
Thanks for the post.
Post by: Laitch on March 23, 2019, 06:50:56 PM
This source was recommended by stokester in this post today (http://www.motobrick.com/index.php/topic,12283.0/topicseen.html#msg108536). Be certain to order 29mm diameter shims only.
newmotorcycleparts.net (https://newmotorcycleparts.net/motor_parts/valve_shims.html)
