TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Shoganai on May 26, 2011, 02:16:21 PM
(http://shoganai.smugmug.com/photos/i-txPpPJR/0/L/i-txPpPJR-L.jpg)
See that screw...I didn't at the time of this photo.
It was worse than I expected.
(http://shoganai.smugmug.com/photos/i-btrqR45/0/L/i-btrqR45-L.jpg)
(http://shoganai.smugmug.com/photos/i-Mk9xVH3/0/L/i-Mk9xVH3-L.jpg)
(http://shoganai.smugmug.com/photos/i-XTDNb9G/0/L/i-XTDNb9G-L.jpg)
Bad gasket, will replace.
(http://shoganai.smugmug.com/photos/i-bMNHHxm/0/L/i-bMNHHxm-L.jpg)
I cleaned off all the loose stuff.
(http://shoganai.smugmug.com/photos/i-wSZzLLL/0/L/i-wSZzLLL-L.jpg)
All cleaned up.
(http://shoganai.smugmug.com/photos/i-zFVCbVj/0/L/i-zFVCbVj-L.jpg)
I had to come up with a way to clean this up w/o trashing the fuel filter.
So I did this and used a SS wire brush and a vacuum to remove most of the debris.
(http://shoganai.smugmug.com/photos/i-dW6TbpL/0/L/i-dW6TbpL-L.jpg)
The wire brush couldn't get it all, so I had to use fine sand paper, and again with the vacuum.
(http://shoganai.smugmug.com/photos/i-swS9QhW/0/L/i-swS9QhW-L.jpg)
(http://shoganai.smugmug.com/photos/i-czLb8Bf/0/L/i-czLb8Bf-L.jpg)
All done until the gasket set gets here.
(http://shoganai.smugmug.com/photos/i-rKG5wDH/0/L/i-rKG5wDH-L.jpg)
Now I picked up that spring, not sure where it came from, but while cleaning up I found another spring.
(http://shoganai.smugmug.com/photos/i-KhFmC8H/0/L/i-KhFmC8H-L.jpg)
As I figured out, the second spring wasn't part of this project.
(http://shoganai.smugmug.com/photos/i-pMtgDNz/0/L/i-pMtgDNz-L.jpg)
I wonder if there is anything I could seal the pitted set with that wouldn't breakdown in the presence of fuel?
Gasket sealants are usually resistant to petroleum products - read the label and it will tell you.
Do you think I should put something like gasket sealant on there?
Sure, why not? I can't see it doing any harm.
Thanks, I'll do it.
