TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Billk on September 10, 2013, 08:27:51 PM
Title: Bicycle Speedometer for a K75
Post by: Billk on September 10, 2013, 08:27:51 PM
Anybody out there try using a bicycle speedometer on there moto?
Recommendations would be appreciated.
Bill
Title: Re: Bicycle Speedometer for a K75
Post by: Grim on September 10, 2013, 09:34:39 PM
Should work. I've seen my bicycle speedo at 52mph. :D
One of the motorcycle aftermarket speedos works the same.
Post by: mjydrafter on September 11, 2013, 12:50:43 PM
Lots of motorcycle uses.  You actually calibrate them based on the tire, so they will work on about anything.  I pretty sure that they even operate the same way as ours, with a Hall effect sensor.
You might also consider a cheap GPS.
Post by: Grim on September 11, 2013, 04:43:18 PM
Might look at this company. These are specifically made for Motorcycle and ATV use. They can be run like a bicycle speedo but I have heard of people building a circuit that allowed them to use the factory speed sensor feed.  They are back lit, larger display then a bicycle one. Some models have Tach. They have a GPS model. THye have motorcycle spicific mounts including some that have lights for Highbeam, Neautral and temp.
http://www.trailtech.net/ (http://www.trailtech.net/) Full line is there but search.
Better price at some of their distributors like
http://www.motorcycle-superstore.com/2/9/195/28761/ITEM/Trail-Tech-Vapor-and-Vector-Indacator-Dash-Board.aspx (http://www.motorcycle-superstore.com/2/9/195/28761/ITEM/Trail-Tech-Vapor-and-Vector-Indacator-Dash-Board.aspx)
And Amazon
Post by: billday on September 11, 2013, 09:36:48 PM
A Sigma 1200, cost about $30, will do the trick. The main drawback is that it's not lit up at night. Here are some installation tips:
http://www.houseofthud.com/bikecomputer.html (http://www.houseofthud.com/bikecomputer.html)
