TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: MikeisonTV on June 15, 2013, 11:52:16 PM
Title: Cafe front almost done, stage 1 exhaust mod, and a trick for rear brake removal
Post by: MikeisonTV on June 15, 2013, 11:52:16 PM
(http://i22.photobucket.com/albums/b329/mikeisdead/null-8.jpg)
Productive saturday...I removed the forks and added some gaiters, lowered the speedo unit, and put in new EBC HH pads front and rear, and stage 1 exhaust mod...more about that in a moment.
 I've seen a good bit of questions on removing the rear brake housing because of the lack of clearance (wheel)...I desided to go about it a different way that was fast and very effective!
I removed the pads with the housing in place!!! I simply popped off the top plastic cover, used a hammer and pick and tapped the pins out...removed the old pads, opened the bleeder valve, pushed the calipers back, and installed the new pads. Enjoy
As far as the exhaust, I drilled holes all around as seen it the photos. My goal, to achieve a louder exhaust. I don't want straight pipes for the loss of power from back pressure, this was my first mod to it.
(http://i22.photobucket.com/albums/b329/mikeisdead/null-9.jpg)
I put a bolt in to see how much louder each hole made, it is noticeable per hole.
Sounds much better. I will shorten it next but that's another day!
Title: Re: Cafe front almost done, stage 1 exhaust mod, and a trick for rear brake removal
Post by: johnny on June 16, 2013, 12:59:23 AM
greetings mikeisontv...
looking good so far... where you gonna test ride it... the ach or the snake...
Post by: MikeisonTV on June 16, 2013, 04:51:54 AM
At Johnny...Little PCH happened right after....sunset blvd to melrose...then home....The 08 R6 to the left of the pic handles the twisties!!
Post by: Brad-Man on June 17, 2013, 04:05:27 PM
What size holes did you use?
Post by: MikeisonTV on June 20, 2013, 03:18:56 AM
I'm not 100% on the size of bit....I'll size it out tom....for u
Post by: frogy on June 30, 2013, 06:26:47 PM
Interesting mod drilling out the muffler.I wonder if it would cause any future problems?
