TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: frankenduck on May 22, 2011, 06:49:47 PM
Title: Fix a flaky or inoperative K bike speedometer
Post by: frankenduck on May 22, 2011, 06:49:47 PM
Many times the cause of K bike speedometer flakiness is poor connections inside of the instrument cluster.  This is especially true for 88 and earlier model years. Here's how to correct the problem:
1) Remove the instrument cluster from the bike.  Exact mounting varies by model but all of them have four 5mm Allen bolts in recessed holes in the back of the instrument cluster.  The wiring harness connector is secured to the back of the instrument cluster either by a Phillips screw or 3mm Allen bolt.
2) Place the instrument cluster face down on a towel on a table.  Remove the nine (seven on 85 and earlier K100s) Phillips screws from the perimeter of the back of the instrument cluster to remove the instrument cluster's back plate.
3) Once the back plate is removed you will see a three terminal connector on the top middle of the back of the speedometer.  It has three long pins on it.  That's usually the culprit.  Pull it straight up.  A small screwdriver can be useful it prying it out.
4) Clean corrosion of of those pins with some steel wool, fine sand paper, whatever.  Then, before reinserting it into the back of the speedometer, twist each of the pins slightly.  That will help to ensure that they maintain good contact when they are reinserted.
5) Put everything back together and go for a test ride to see if that fixed the problem.
Title: Re: Fix a flaky or inoperative K bike speedometer
Post by: Photog on May 28, 2011, 08:57:03 PM
What about flakyness of the clock and/or gear indicator?
My clock has segments which don't activate, and the shift indicator doesn't like cool or damp weather. It starts randomly displaying different numbers.
Any "standard" fixes for these?
TIA
Post by: frankenduck on May 28, 2011, 09:14:27 PM
TIA
The LCD is shot on your clock. No fix other than replacing it with a good one.
On the gear indicator it's probably water getting into the switch on the back of the transmission. They live a hard life down there and eventually disintegrate.  The standard fix is to replace the gear indicator switch.  (It's possible that it's the wiring harness connector but the switch is the usual culprit.)
(Tomorrow morning I'll add a gear indicator thread to the Lieberry to explain how it works and how to troubleshoot it.  I have to go BBQ some NY steaks right now. ;D)
Post by: billday on August 19, 2011, 06:41:45 PM
While you have the instrument cluster apart,  give it a few hours in proximity to a dehumidifier. I've had my speedo go duff a few times: once from a mucky sensor (when the final drive still had PO's gear oil in it), the other times from moisture getting into the cluster (while parked outside in driving daylong rain).
Post by: rbm on August 20, 2011, 07:39:44 AM
Before reassembling the three pin connector, it would be good to spray it with DeoxIt.  This product is much more than a contact cleaner; it contains chemicals that form a protective film on the connector pins that will inhibit corrosion in the future.  It would be advisable to treat all contacts in this manner while the speedometer is open.  This is good preventive care to apply to any K-bike connector while it's apart as it will delay the onset of poor-connection-related problems.
Post by: billday on May 21, 2013, 04:55:50 PM
I did  this today -- and it worked! Except.... I have no idea what he means by prying the connectors out, because they are mounted to a piece of plastic that does not want to lift off anything. But there was room to lift the connectors a bit then reseat them, and I gave them a shot of DeOxit. Put everything back together and voila, speedo and odo. Thanks once again Frankenduck!
Post by: k98DOG on August 05, 2013, 11:07:15 AM
Where exactly is said monster?
Quote
Post by: billday on August 07, 2013, 02:00:14 AM
Just north-northeast of that blue "075" in your picture. See those three rivet-y looking things?
Post by: k98DOG on August 10, 2013, 05:37:56 PM
Clarification??
Post by: heller on June 19, 2015, 02:57:47 PM
My Speedo on the 93 k1100rs just flaked.  I've read through these boards and now am looking for some more detail specific to my unit.  I took the speedo off and cleaned up the contacts.  Also cleaned the contacts at the right side cover and on the final drive.  I opened the unit up and really didn't see any serviceable connections.  Worried that something would break.  Couple of questions: 1) can I use a "contact cleaner and spray the circuitry.  Should I take the unit apart further?  Will the bike run if I screw things up more than there already are?  Also, how about dialectic grease on the pins.  Also, I saw once a detailed description of twisting pins with a pliers to improve the connections.  Now I can't find that bit. I'd also love to see some video instruction on troubleshooting these instruments.  Any help would be much appreciated.
Post by: rbm on June 19, 2015, 05:56:42 PM
Yes.  Deoxit is recommended.
Quote from: heller
You can.  Just be careful.  You don't have to disassemble the entire unit.  A couple of posts back there is a photo of the interior of the gauge.  You're looking to clean the 3-pin contact pointed to by the arrow.
Quote from: heller
Yes.  You may loose "enable start while in neutral" but you have "pull in the clutch" to override that.
Quote from: heller
No, bad idea.  Dialetric grease is not conductive and with the millivolt/microamp signal coming from the speedo sensor, you'll do more damage than good.
Quote from: heller
Read the page on Karamba (http://www.k100-forum.com/t2038-karamba-speedometer-calibration-program-tutorial).
Post by: heller on June 20, 2015, 01:12:46 PM
Thank for the help.  As I was walking by, bumped into the mirror and it popped off!  I am doing the leash thing next.  Any tip on how to reattach it?  Is it slid back over the posts or pressed back in place?
Post by: johnny on June 20, 2015, 01:43:22 PM
greetings heller...
welcome to motobrick.com...
line up the 3 mirror side cups with the 3 moto side nubbins... with the clips touching the nubbins in perfect alignment... smack it straight with the palm of you hand... should go straight on...
Post by: RobP on September 13, 2015, 01:49:33 PM
Thanks for posting this.
I cleaned up the speedo pins as recommended.  They seemed a bit loose in their socket connections, but I reassembled and went on a test ride.  The speedometer wonkiness still was present, although not as bad.
I removed the gauge cluster and rear cover again.  Taking care not to overstress and break the plastic, I pulled the plastic wing with the pins OUT as far as I dared, then pushed it NORTH while holding it out at the same time.  The intent was to bend a very slight angle in the pins so as to cause them to bind as they settled back into the sockets and to improve the mechanical connection.  That seemed to do the trick, as in the follow-up test ride my speedometer and odometer worked perfectly.
Post by: mg1 on January 06, 2017, 11:26:20 PM
Hi
Thanks for this excellent resource - I'm using it to guide me in fixing my wayward speedo, but I've run into a small issue:  the three pin plug does not want to come out, and I'm wary of forcing it to do so. Also the attachment point looks different on my speedo (92 K11RS) compared to the image earlier in the thread, in that the three pin plug enters a small housing secured by two screws.  It occurs to me that the plug may be secured on the other side of that housing, but I'm wary of undoing the screws too in case something underneath should not be disturbed.  I'd appreciate advice from anyone who's been in this position before me on how to proceed from here. I may appear a little timid, but I'm a notorious klutz so better safe than sorry.  Image attached.
thanks from
Martin (the other Aussie one)
in the sunny Riverina
Post by: mg1 on January 07, 2017, 12:46:14 AM
Never mind, took  little screws out, found ribbon plug is attached to plastic plate secured by two screws.  Took plug out, seemed very clean and tight but have given them a light rough up and some contact cleaner, will reassemble and see how it goes.
regards
MG1
Post by: Laitch on January 07, 2017, 07:18:38 AM
:2thumbup:
Be sure to clean the main connection plug, too.
Post by: Martin on January 07, 2017, 02:47:21 PM
OZ Martin # 2 go to Jaycar they have a product called Deoxit and Dielectric Grease. Bricks really benefit from clean electrical connectors. I use dielectric grease or heavy silicon grease and have not had any contact problems where I have used it. However other inmates discourage it's use in connectors, my belief is that it stops air and moisture getting in which will discourage corrosion. Your call on the grease.
Regards OZ Martin # 1.
Post by: alexis291 on January 09, 2017, 08:09:58 AM
A couple of tips from when I had instrument cluster problems:
1. My erratic speedo reading turned out to be the needle touching the scale behind it because the scale had come loose and lifted up slightly. I simply undid the screws which hold the scale down, smoothed it out and all was okay.
2. Packets of silica gel in the back of the cluster stopped my condensation problem after I had tried a few of the other fixes on this forum. The cluster has just started to fog up again after about 10 months so I will replace or dry them out and re-fit.
Post by: thecableguy on January 09, 2017, 11:43:20 AM
Another tip on a flaky speedo. One of the "fixes" BMW promulgated back in the day was to paint the pins on both the three-pin connector and on the main connector with conductive paint.  On mine, apparently the tech got overzealous with his paintbrush and a bit too much ran down the pin and pooled at the base.  In my case the pin in question was on the main connector and was shorting it (intermittently when warm) to the next pin.  Scraping the excess paint from the base of that pin cured my speedometer issues when none of the other fixes worked.
Took me months to figure that one out.
Jim
Post by: swanwr on May 25, 2017, 09:31:40 AM
I'm still having speedo troubles---I cleaned and did a continuity checks on all the connections, including the 3 pin connector in the speedo housing (twice).  I did the soldering iron trick the speedo reads the 45ish MPH like it should, but it sets on 0 mph when I ride the bike.  I assume the sensor isn't picking up the wheel inside the final drive.  Any idea?  There are no shims on the sensor and I don't see any adjustment for it.  Back story is, the speed went from working all the time to not at all, no flaky in and out.
Post by: thecableguy on May 25, 2017, 03:21:09 PM
If it's working with the soldering iron, my first action would be to pull and clean the sensor.
Good luck!
Jim
Post by: swanwr on May 26, 2017, 12:58:38 PM
The problem ended up being the pickup ring inside the final drive.  It's loose.  Anyone have experience/instructions on taking the final drive apart to repair this?
Post by: Laitch on May 26, 2017, 01:12:19 PM
https://www.motobrick.com/index.php/topic,580.msg9690.html#msg9690
Post by: swanwr on May 27, 2017, 03:36:29 PM
Good info. Is the speedmeter ring pressed onto the FD shaft behind the tapered bearing?  Just trying to figure out what to look for before I dive into it.
Post by: Supershooter on June 24, 2017, 05:29:43 PM
Tore my gauge cluster apart, and found a dried up gasket and rust inside. Can this be fixed? Or should it be replaced?
Supershooter
Post by: wmax351 on June 25, 2017, 10:22:06 AM
Supershooter
Depends what you're time is worth, and if you like the mileage being correct (though you could correct the mileage on an ebay cluster if needed too).
You can very carefully disassemble those cables, and clean the contacts. Often those rusted ones get loose too. If there are breaks in the cable or circuits on the PCB, you can even very carefully solder "airwires" on to them, to restore function. I had to do it in mine.
Post by: Supershooter on June 25, 2017, 01:10:42 PM
Don't know anything about circuit boards, are there any how to's on YouTube?
I wouldn't mind fixing it myself, but don't know where to start, and am concerned about breaking it beyond repair, which I guess shouldn't be a concern since it doesn't work now.
Supershooter
Post by: wmax351 on June 25, 2017, 05:34:59 PM
The soldering is going to be tough, since it's not even normal circuit type soldering.
Your best bet is to carefully try to disassemble it and clean it, I'd use Pb-catalyst seized bolt remover.
Post by: Martin on June 25, 2017, 05:52:14 PM
You can get liquid solder in a tube (conductive glue) try Jaycar. It might be easier, use a contact cleaner in conjunction with cotton buds.
Post by: rbm on June 25, 2017, 06:08:34 PM
To solder air wires on the flexible circuit strip will require a temperature controlled soldering iron that can be set to 600 *F, 63/43 solder in 0.039" diameter to control its application and lots of flux to ensure good solder flow and wetting.  That's achievable but specialized.  Better to see what you accomplish with conventional cleaning tools and products.
Post by: Laitch on June 25, 2017, 07:18:55 PM
Which makes me wonder if wmax351 is considering a career in vascular or neurosurgery.  :yes
Post by: wmax351 on June 25, 2017, 09:21:17 PM
If I go procedural, more interested in Interventional Radiology or Interventional Cardiology. So essentially doing the soldering through the holes where the wires come out.
Post by: Nomatch1 on July 06, 2017, 11:25:26 AM
Hi,
I have had a non working speedo on my 85k100 since I got it years ago. I am trying again. Wire connectors checked but the soldering iron does not make any effect. I checked the connection points at mid bike connection and did the soldering iron proximity test. The meter reads 1 and does not change the resistance. If this is having no resistence effect does it mean that the sensor is bad?
 I have cleaned it, the ring insteam rear drive is attached and spinning.
I have not seen any sensors available onlone anywhere.
I did not yet call a dealer lest I go into shock.
Any ideas for me?
Barry
in WV, 85 k100 rs, 50k,,,guessing
code 0513 I think  (not sure how to tell what month it was made)
Post by: BrickMW on July 06, 2017, 11:44:20 AM
Here is one source (https://www.euromotoelectrics.com/searchresults.asp?Search=speedometer&Submit=Submit).
Not too bad a price, only $4.95 more than my odometer gears.  :2thumbup:
Post by: Nomatch1 on July 07, 2017, 09:28:28 AM
Is there a dependable way to be sure that the sensor is dead, before buying one?
I did find a used one for $50, is this a good idea or would new be a smarter option?
Post by: rbm on July 07, 2017, 04:28:24 PM
Before springing for a new sender (which is unlikely to have gone bad), perform some tests using your PC and a program called Karamba.  My Karamba tutorial is on the K100-forum site (http://www.k100-forum.com/t2038-karamba-speedometer-calibration-program-tutorial) and should serve as a test instrument for you to isolate the problem with your Motometer.  Since it's off the bike, troubleshooting will be much easier.  Building the sound card adapter cable that Karamba needs is easy.  If you can't locate the program, then PM me.
Post by: Nomatch1 on July 12, 2017, 10:19:41 AM
Robert,
 Thank you for the Karamba advice. I am rounding up the parts to make my wiring rig. I will keep you all informed.
Barry
Post by: rdivy725 on February 03, 2019, 02:32:44 PM
Greetings,
Got the flaky Speedo issue, got the cluster out and hit the 3 pin with Deoxit, should I use DC 4 insulating compound on it? I was def going to use it on the bulk connector...
Post by: FlySpur on April 29, 2021, 02:01:26 AM
Mine has started acting funky as well. I will try the solutions posted above and will share the update how things go afterwards.
Great thing I saw this thread.
Post by: Laitch on April 29, 2021, 06:58:36 AM
112350
Post by: FlySpur on November 27, 2022, 04:45:59 PM
its been a while and I figured I haven't shared the update. I did clean the contact, assembled everything back again but that actually didn't help. I noticed that tacho operates normally after riding the bike for over than 20 min. However, turning off the engine and starting it back again even after short stop - and tacho starts acting up again. Well, not being able to sort it out I just ride it the way it is
Post by: Gabriel70 on January 07, 2023, 05:25:29 PM
My issue with a flaky speedometer which eventually stoped working was due to a faulty circuit board. The thin, long board in the bottom right corner, looking at the instrument cluster with the back cover removed.
there was corrosion of the circuit board tracks due to moisture in the cluster. I replaced a faulty capacitor and the speedometer is now working.
Just my experence..
