TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: tsbt on May 28, 2013, 10:48:03 AM
Title: ABS Shims and a cryptic scan job
Post by: tsbt on May 28, 2013, 10:48:03 AM
Need to replace my abs sensor shim on the front it's squealing like a pig obviously too snug. Can't seem to decipher which size shim I should order from the K100rs manual microfiche because it's all pixelated. Any idea what size is standard? I feel like 0,100mm might be the right measurement but I'm not sure.
Title: Re: ABS Shims and a cryptic scan job
Post by: Grim on May 29, 2013, 12:25:11 AM
Use the shims off the back to experiment till you find the right combination then order.
