TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: sh00ter on May 24, 2013, 11:10:30 AM
If there's a topic about just this; someone send me the link?
When I took the rubber boot off the front of the final drive (#14 below) there was a bit of oil that leaked out - i'd say maybe a tablespoon? This is likely the first time it's been removed in 20k miles (since new). Something to worry about ? I read that, based on the fact that the swing arm inside was dry, it likely came from the forward seal of the rear drive. Don't want that giving out - but having that puppy rebuilt isn't in the cards either right now. Thoughts?
(http://i.imgur.com/LNB0lW9.png)
greetings chooter...
i would not worry about it... i would just check the innards of the swing and figger out if its coming from the gear box or the final drive... then crack that fill hole open on a regular basis to make sure i gotts the proper amount of juice in there...
the bugeye motobrick did that for 60,00 + miles... always a couple spoon fulls of juice in there butts never more...
look on the bright side. if it holds oil inside, at least you don't have a torn boot.
