MOTOBRICK.COM => The MBdotCOM Community Center => Topic started by: TaosBrick on May 18, 2013, 01:20:39 AM
Between Ludlow and Barstow on the 40. OMFG - 45 mile an hours from the SW with random gusts considerably greater. That was one hard won fifty miles. Going for beer. Now.
its like that just about everyday out there... all the way to the top of the 178... then you should be good...
keep us in the loop as to how your ride is going down...
Weelll... At this point, most anything (I know I'm temptin' fate) would be better than the last hour or so of leaning sideways around crazed truckers while trying hard not to be blown under their wheels.
dontch luv it when a truck sneak up beside you, blocks the wind and you're leaned over careening right into his rig? :riding: :falldown: :hehehe
None too fun. Not only was Brenda passed by the truck, but a big gust happened at the same moment that wrapped around the truck and combined with the backdraft to almost push under the trailer wheels. Took a fair amount of PBR and Sam Adams to smooth out the nerves.
Find beer to proportionally as expensive as ga$online in certain parts of the golden state.
Been there, done that - not much fun at all, but it does make the beer taste better!
Good lord, they still make that swill???
Midwest boys long ago induced the digestive enzymes to cope with PBR.
"What'll YOU have?"
As for worst wind ever, I have both the standard K100 and a 2002 K1200LT. The stretch between Albuquerque and Gallup on I 40 regularly exceeds 50 mph winds (usually out of the southwest, with gusts that are hurricane force, particularly around where Rte. 6 meets the Interstate). The K1200LT is much better at slipping through and resisting that wind than either the '96 Goldwing I had, or the K100.
I have a National Cycle small deflector screen on the Nekkid Brick, and the technique I use in the high wind is to get my jewels up on the tank and lean forward so that I am practically laying on the tank with my knees almost touching the grips of the tiller. The idea is to get my weight both forward and down, and to use the push-pull on the bars to countersteer as one would with strap-ons, i.e., forcing the tipover with the front gyro instead of trying to be fast at moving my weight around. It's a little tiring to ride like that, but the bike responds much more quickly as compared to sitting bolt upright and shifting my weight to lean or turn.
Also, I try to be moving at least 10 MPH faster than the 18 wheelers so as to blast through their wake turbulence quickly.
As we used to say in the Air Force. "Prepare to copy CAT message: Michael Echo Oscar Wyoming."
Yeah, LA - I know that stretch of 40 well. Can be just as bad, sho 'nuf.
PBR? Breakfast of Champions!
Been around Ramah a few times.
There are some beeutiful lightning storms there 'bouts round about 3 pm.
Question; Does the 's' model k75 get thru it any 'better' with it's riding position?
Trying to get home after a 12 hour stint at the restaurant; Had a rouge thunderstorm on my buttocks for the entire ride (32 miles) kept out in front but as the pressure was changing gusts would swirl up to 40 mph then nothing then completely different direction; impossible to find body position to steady the 94 k75s out. Pulled into brick-shed and the sky just opened up...went in and talked with Don Julio and pulled up NOAA's radar loop noting that the storm and I had both taken I-65 north>I-40 W>Briley PKWY north and Hwy 12 to Ashland City...Hateful
Nashville area eh, BrickDanger? See you there next May when I go to perform at the Tennessee Renaissance fest on my trusty Chile Red.
