BMW K75F_Brake_Turn_Signals.avi (http://www.youtube.com/watch?v=_twRIPIPwsE#)
I'm running a Kisan Signalminder SM-6 because that lets you run LED turn signal bulbs without getting the hyperflash that the stock flasher relay would give you. Since LEDs draw a very small current that means that I can use small and inexpensive PCB (printed circuit board) relays that I get on Fleabay for about a buck a piece. I solder the wires to the pins, then wrap the relays in electrical tape and then fill that up with five minute epoxy to make things permanent and waterproof.
(http://i82.photobucket.com/albums/j246/smithduck/stop_turn_relay.jpg)
Circuit design attached.
