TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: jeffhestand on May 09, 2013, 11:16:12 PM
got to the inside of the the tranny and the grub screw is very obivous that it is loose. I feel with some long allens i can loc tite and tighten without a lot of disassembly.... i am concerned though about where the shift lever should be set before i tighten it down. Is there a detent or a flat this screw if tightening into or should i just loctite, tighten and hang it back together? I have a feeling many owners have done this before??? thanks again ! :yes
is there a write up on this site or any other site that anyone knows of for the grub screw procedure and getting the foot shifter in the right spot before retightening and loctiteing.... etc.. thanks!!! :bmwsmile
Have you seen this? BMW K75 K75S Clutch Spline Lube 2of3b (http://www.youtube.com/watch?v=zVea8TByyT8#)
no i havent. Watched a little of it already and this is EXACTLY what i was looking for .... THANK YOU :clap: I will watch it at length with a cup of coffee in the Am ,. Thanks Jeff
great, just when I thought I was done.....
