TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: tsbt on May 09, 2013, 04:56:20 PM
Title: Transmission Seals à la carte
Post by: tsbt on May 09, 2013, 04:56:20 PM
Going back in to replace a couple of transmission seals.
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/249064_10200541436751970_612951263_n_zpsb9cc8ad8.jpg)
Title: Re: Transmission seals
Post by: jeffhestand on May 12, 2013, 10:37:47 PM
which seals.... i currently have my tranny out having just loctited the grub screw . Wondering which seals you were doing since i have oily residue below the clutch pack on the bell housing. Some say replace the clutch nut oring some say a main seal. The clutch pack is intimidating me right now so im not sure what to do. Any advice?
Post by: tsbt on May 13, 2013, 09:34:51 AM
There are 3 seals in the transmission to my knowledge, two on either ends of the drive shaft and one on the output shaft - I might need to change bearings while I'm in there we shall see.
I replaced the clutch o-ring and main seal on mine, it was leaking everywhere, the main seal was the toughie I had to fashion a custom tool to install it: http://www.motobrick.com/index.php/topic,2652.msg15008.html#msg15008 (http://www.motobrick.com/index.php/topic,2652.msg15008.html#msg15008)
Title: Re: Transmission seals part deux
Post by: tsbt on May 31, 2013, 08:34:52 AM
Scalpel...
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/photo3_zps322693b0.jpg) (http://s1165.photobucket.com/user/thespacebetweenthings/media/photo3_zps322693b0.jpg.html)
bleeding from the input
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/photo1_zpse7ea011e.jpg) (http://s1165.photobucket.com/user/thespacebetweenthings/media/photo1_zpse7ea011e.jpg.html)
in the bucket...smells like sulfer so it's definitely the transmission...
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/photo2_zpsa89c24f1.jpg) (http://s1165.photobucket.com/user/thespacebetweenthings/media/photo2_zpsa89c24f1.jpg.html)
everything looks okay at first glance...
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/photo2_zpsc6a35637.jpg) (http://s1165.photobucket.com/user/thespacebetweenthings/media/photo2_zpsc6a35637.jpg.html)
then again, I'm not really sure what I'm looking for...
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/photo5_zps0856e1b1.jpg) (http://s1165.photobucket.com/user/thespacebetweenthings/media/photo5_zps0856e1b1.jpg.html)
so I'm here to change three seals, input, output and needle...sure is dark in here, bearings feel solid...
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/photo4_zpsa5453042.jpg) (http://s1165.photobucket.com/user/thespacebetweenthings/media/photo4_zpsa5453042.jpg.html)
shifter is always super sticky while shifting, but I hear you really gotta give K's the boot when shifting, probably normal...
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/photo1_zpsa887c044.jpg) (http://s1165.photobucket.com/user/thespacebetweenthings/media/photo1_zpsa887c044.jpg.html)
a few more random photos so I can inspect later...
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/photo1_zps9e0f013d.jpg) (http://s1165.photobucket.com/user/thespacebetweenthings/media/photo1_zps9e0f013d.jpg.html)
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/photo3_zps257c691c.jpg) (http://s1165.photobucket.com/user/thespacebetweenthings/media/photo3_zps257c691c.jpg.html)
(http://i1165.photobucket.com/albums/q588/thespacebetweenthings/photo3_zps1cb7fbad.jpg) (http://s1165.photobucket.com/user/thespacebetweenthings/media/photo3_zps1cb7fbad.jpg.html)
The transmission is just resting on a bench I don't really have anything to stabilize it so i'll see if that's an issue as I get further along...I also need a bearing puller, and I hope to get by without any special super-duper-bmw-tools that don't exist anymore... :beehive:
Title: Re: Transmission Seals à la carte
Post by: lunchbox on June 01, 2013, 03:00:00 AM
There is also a seal on the shaft for the toe shifter and a seal on the clutch pushrod. I used a socket of the corresponding size for tapping in each seal, no leaks two years later.
Post by: cy7878 on June 01, 2013, 10:28:30 AM
and the cover next to the output shaft is also recommended to be changed.
Post by: tsbt on June 01, 2013, 10:37:18 AM
Thanks, would've missed that.
And this as well. Only want to do this once!
