TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: mrcasual666 on April 26, 2013, 11:50:12 AM
Just noticed the Works Performance rear shock on my '92 K75S is dribbling fluid. I'm assuming a seal needs to be replaced. Works quoted me around $110 to replace the seals and the shaft, if needed. Seems reasonable. The problem is it takes 3 weeks, plus a week of shipping time each way from NYC to Canoga Park, CA.
Is there a shop in the NY/NJ/CT area that could do the work, or does it need to be sent back to Works Performance? Or is it possible to do yourself?
Thanks!
Pete
Called around and it doesn't seem like anyone but Works can do the maintenance. I swapped the Works shock out with the original BMW shock over the weekend, which was pretty simple. The trick was setting the incoming shock to the softest setting so it was short enough to fit into place.
I sent the Works shock to CA today, $12 for two day deliver with USPS flat rate shipping. Works says it takes about 3 weeks to turn it around, $75 for new seals, another $45 if it needs a new shaft.
In the meantime, the original BMW shock seems like its in decent shape, except the rubber guide at the bottom is cracked pretty bad. Is that a deal breaker?
