TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Big_B on April 10, 2013, 09:44:21 PM
I've been having issues with my bike. It started with a bad ignition switch which I thought was a dirty starter. I fixed the ignition switch, but hitched the negative cable to the starter post, which I later find out is the positive. Hit the starter starter button and the positive started to throw sparks. so I disconnect the positive wire. The bottom line is that I made a stupid mistake and shorted the battery out for anywhere between 5 & 10 minutes.
I finished up installing the starter and putting the ground cable to the proper spot, then put the charger on my battery. Started the bike, which ran like crap at first, but then seemed to smooth out. Went to fill my tank and left the station only to have the bike start surging within 3 miles. Make it home and put the charger on the battery and call it a night. The battery is 1 year old and always performed well for me.
I woke up this morning and notice that the battery isn't fully charged. Hmmmmmm checked the battery with a multimeter and it's showing 16 volts! I also notice that there's not much acid in the battery and I top it off with fresh acid. Charged it for a little bit, check the voltage and it reads 14.4 volts, perfect. Throw it in the bike and she will idle great, but the motor cuts out with any throttle at all. I check the voltage with the key on and the voltage is dropping rather quickly from 13.6 to 12.39 within maybe 1 minute. I throw the charger back on it and the voltage is climbing just as quickly, maybe a full volt within a minute. I know it's a bad sign when the battery charges or discharges rapidly.
My questions are will the bike idle fine but totally die when any throttle is applied from a bad battery? Will an otherwise good battery go bad if it's shorted out for 5-10 minutes? And finally, what's the expected life span of a battery in these K1100's? I would sometimes put it on a trickle charge, if it was very cold out, to maintain it.
Once again any help or opinions are greatly appreciated! :2thumbup:
A bad battery can do a lot of weird things.
I'd be more worried about running the bike too much with a bad battery and further chancing damage to the alternator.
Shorting it out like that most likely damaged the internal plates, if not at least cooked the acid.
I gather that it's a wet cell battery and not a sealed gel.
If you have access to some, you could try and dump/drain and neutralize the old acid and refill the battery with some fresh and put a charge on it to see if it will recover.
Other than that I'd suggest replacing it with a gel sealed battery.
5-7+ years of service would be considered good for any bike battery.
The Odyssey 680 (http://www.amazon.com/gp/product/B0002ILK6I/ref=as_li_ss_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B0002ILK6I&linkCode=as2&tag=cinematographyco) is a popular choice for the K-bikes.
Put something non-conductive over the + terminal so it won't accidentally short out on anything, including the battery clamp.
