TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Big_B on April 08, 2013, 04:26:18 PM
Title: Negative battery wire mount
Post by: Big_B on April 08, 2013, 04:26:18 PM
After tearing my K1100 apart to repair the ignition switch I forget where the negative goes on the motor/chassis. It looks like it attaches to the starter, but I don't want to blow something over a simple mistake.
Does anyone know where the ground/negative wire is mounted to the motor or chassis? :dunno2:
Title: Re: Negative battery wire mount
Post by: Scott_ on April 08, 2013, 07:45:08 PM
Either one of the starter mounting bolts should work just fine.
Post by: cy7878 on April 09, 2013, 10:51:21 PM
you can pretty much mount it anywhere.  But the actual spot is to the left side of gearbox housing, right next to the starter.  I think it's held my a 3mm hex bolt.
Post by: Big_B on April 09, 2013, 11:24:44 PM
I ended up putting on the stock location right above the shit shaft. Thank you for the replies.  :2thumbup:
