TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: K75RT Keith on March 30, 2013, 03:33:56 PM
Title: K75RT Starter Bearing lubricant
Post by: K75RT Keith on March 30, 2013, 03:33:56 PM
The starter is apart and the front bearing looks like it could use some refreshing.  What type of grease should I use?  Lithium?  Moly/Spline Lube?  Bacon?
Title: Re: K75RT Starter Removal
Post by: TimTyler on March 30, 2013, 04:20:47 PM
There's an O-ring seal near the tip that might be sticking.
You want to pull the starter straight back with some muscle.
Post by: cy7878 on March 30, 2013, 05:09:06 PM
Hi,
  I had the same problem trying to remove the starter on my K100.  Lee told me to rotate the starter first clock and counterclock wise to break the seal, then wiggle to get the back out.  WOrked like a charm.
Post by: K75RT Keith on March 31, 2013, 12:10:48 AM
After some time and effort I got the starter out.  Wiggle, twist and pull seemed to work.   Thanks for the advise!
Title: Re: K75RT Starter Bearing lubricant
Post by: TimTyler on March 31, 2013, 12:58:33 AM
Why did you edit your original post and topic title?
Post by: cy7878 on March 31, 2013, 01:16:41 AM
I was wondering why my answer didn't seem to make any sense now.
Post by: K75RT Keith on March 31, 2013, 11:35:46 AM
NO, Your answer was correct.  I changed the title rather than start a new thread.
Post by: cy7878 on March 31, 2013, 03:31:41 PM
I think both Tim and I (at least I) were trying to say was leave the thread the way it was.  If people in the future ever do a search on how to remove the starter, then the answers will make more sense.
As to your new question on bearing.  I'm sure there are going to be different opinions on this.  But my own understanding on this is that bearing manufactures pack a thick grease inside for longevity reasons, and although it has more resistance and attracts dirt, the grease really isn't going anywhere.  However, when maximal performance is called for (meaning you would want lower rolling resistance), or when the bearing is cleaned with cleaners, the grease gets washed out.  This is good for a while, but then you will need to relube the bearings subsequently and frequently to avoid insides getting dried out.  There is really no way to repack a ball bearing.
So as far as I know, you're better off wiping the dirt and grime away from the outside and leave the inners alone.  I'm interested in what other people think on this as well.
Post by: JamesInCA on April 01, 2013, 01:15:51 PM
Yes, please make new threads for new issues. The supply of threads is not constrained; they're really quite inexpensive.
By removing the old information it not only places subsequent posts out of context and makes them confusing, it also diminishes the value of the board for future searchers looking for solutions to the same problems.
