TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: k11pfc on March 28, 2013, 08:18:48 AM
Title: K11 pig to fire up
Post by: k11pfc on March 28, 2013, 08:18:48 AM
My 1994 k1100rs, 31k on the clock is a pig to start if its been left, even overnight especially in the cold, it always catches eventually but just doesn't fire quickly and certainly much longer than it should be, the fuel pump works I keep the 'choke' at the halfway point, battery is always fully charged, I leave the throttle alone as always but it's just a pig to fire up. Any ideas?
Title: Re: K11 pig to fire up
Post by: Snowy on March 28, 2013, 01:40:23 PM
In cold weather, push the "choke" all the way to the stop. When the engine fires, let the "choke" stay on the halfway point.
What's the engine idle speed when its warmed up?
Post by: k11pfc on March 28, 2013, 01:57:21 PM
It runs just at 1000 rpm, it runs very sweet it's just a bit of a pig to start
Post by: pallum on March 28, 2013, 09:24:18 PM
I had similar problems starting below freezing. I checked valve clearances and found 3 to be tight beyond spec. Tight valves are a suspect for any engine with hard start ups, too. All you need is a 10mm socket, needle nose pliers, a set of feeler gauges, a little rtv sealant and about an hour!
Post by: johnny on March 29, 2013, 01:07:57 AM
greetings k11pfc...
sounds like it need to be ridden hard on a regular basis... a 94 with 31k kilometers... i think its being a drama queen from lack of attention...
motobricks aints no garage queens... they must me ridden hard and often to be happy...
Post by: Bassv on March 29, 2013, 09:19:34 AM
Just like my girlfriend!
Post by: mystic red on March 29, 2013, 09:57:24 PM
 :2thumbup: :hehehe
Post by: k11pfc on March 31, 2013, 03:40:58 PM
In my defense I bought it 18 months ago with 7k miles on it!! Anyway someone suggested flicking kill switch a few times before starting in case the filter is a bit dirty, so I tried this and its started fine the last 2 days in temps of around zero so hopefully I'll change the filter and it'll be fine. Hopefully.
Post by: KCinSB on April 02, 2013, 09:59:23 AM
Wow,.......  I'd be a Pig to start around zero degrees TOO !!!
Post by: bocutter Ed on April 02, 2013, 10:31:57 AM
That would be centigrade in the UK, or 32F. That's near the temps we're having in Toronto this time of year (-3C this AM). Nice riding weather. Went for a 50km(30 miles) ride north to my sister's place for Easter dinner on Sunday at about 8C(46F). Wasn't cold even at 135kph(84mph).
Post by: JamesInCA on April 02, 2013, 12:18:22 PM
How old is the battery? Even if it's reading as fully charged, it might not be able to deliver the full current required for a good clean start.
My sketchy winter starting cleared up last year when I replaced the battery.
