TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: WayneDW on March 10, 2013, 06:35:13 PM
Today I took the "bushings" (I would call them air ducts) off the top of the throttle bodies on my K75 while I wait for new ones to be delivered. I cut the one-time-use clamps and plan on using standard hose clamps upon installation. The problem is that all the clamps that I find are 1/2" wide but the recesses in the bushings for the clamps are only 1/4" wide.
Do I need to find a source for such a clamp or do I just ignore the difference and clamp em down good and tight?
Thanks in advance for the help.
Try McMaster Carr. (www.mcmaster.com (http://www.mcmaster.com))
To replace the clamps for throttle bodies, check out McMaster-Carr p/n 5388k32
Also, have you seen this writeup? http://www.motobrick.com/index.php/topic,624.0.html (http://www.motobrick.com/index.php/topic,624.0.html)
Check Ebay or Suzuki dealerships for 48mm Suzuki band clamp part number 09402-48208 for TB->bushings and bushings->air plenum. I bought a quantity from a Florida Suzuki dealer for $4.78ea last year. They are black which is nice.
Perfect,
I agree, black clamps will be nice.
Thanks so much to each of you.
W
