TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: TimTyler on March 03, 2013, 04:24:10 PM
Title: Checking Brake Pad Wear on K75
Post by: TimTyler on March 03, 2013, 04:24:10 PM
What's a worn brake pad look like when viewed while it's installed? I could not see any wear indicating marks.
Title: Re: Checking Brake Pad Wear on K75
Post by: frankenduck on March 03, 2013, 04:41:39 PM
Min spec is 1.5mm.
Post by: TimTyler on March 03, 2013, 04:51:05 PM
Thanks, Duck.
I pulled out one of the pads and I'm good at 4mm.
Post by: frankenduck on March 03, 2013, 06:21:07 PM
In reality it really doesn't matter unless it wears all of the way down to the metal back of the pad and destroys your rotor.
Post by: Chaos on March 03, 2013, 06:33:38 PM
Sometime when they get around 1mm or so the pad can flake off all at once.  Don't ask
Post by: rbm on March 03, 2013, 09:57:59 PM
My experience is that as the pad material thins,  it tends to squeal more readily.  The back brake on my K75 was making a racket and, when I checked the pads, they were at minimum thickness.  No squeal with the new pads.
Post by: frankenduck on March 03, 2013, 10:19:54 PM
Disc squeal is caused by high frequency vibrations as the caliper pistons vibrate against the backs of the pads. Very easy to cure by spraying this on the backs of the pads:
(http://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage//N3223/large/7160218_ptx_80077_pri_larg.jpg)
Post by: Qdude on March 04, 2013, 12:29:04 AM
I have found that the squealing can be cured by applying a thick layer of grease to the rotors as well.
Stopping then becomes an issue though.
Post by: Mitcam62 on March 18, 2013, 08:46:12 AM
Makes for an interesting ride though, no? LOL!
Post by: Chaos on March 19, 2013, 12:23:33 AM
Apply the grease evenly to both sides or you will stop in circles  :loco:
