TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: grant71 on February 23, 2013, 03:06:48 PM
Title: K100rs fuel pump relay
Post by: grant71 on February 23, 2013, 03:06:48 PM
i understand from the Lieberry catalogue that the fuel pump relay is on the left front in the relay box. please  correct me if i am wrong. Question is : how does one remove this relay from its station without damaging it. As posted in a previous Workshop my K100 rs will not start. engine turns  over dash lights are on but engine will not fire.
Title: Re: K100rs fuel pump relay
Post by: Inge K. on February 23, 2013, 03:34:24 PM
The relay you pull straight up from the socket.
Have you checked if you got power at the green/white wire at the tank connector, when
you push the starter button ? (you got a 2V if I remember correctly?)
Inge K.
Post by: grant71 on February 24, 2013, 05:08:40 AM
thanks Inge. yes i put a tester on that 4 strand wire from under the tank. no continuity. But then being a novice it did not occur to me to press starter button. im waiting for a friend with a trailer to go fetch the bike. ill do it properly once its in my garage. Yes it is a 2 valve.
Post by: grant71 on February 24, 2013, 12:48:09 PM
Inge. i tried for power on green white wire while starter button pushed. Nothing. i pulled the left front relay. Looked clean. replaced no. 6 fuse which according to Haynes is fuel pump. Nothing. now im stumped. dont know what else to try. Any suggestions please
Post by: pdg on February 24, 2013, 01:43:26 PM
Couple of silly questions:
Was the ignition on when you were pressing the starter button to test for voltage? Was the engine turning over but not firing?
Post by: Inge K. on February 24, 2013, 02:07:48 PM
Engine turning, but no power to the fuel pump,,,Paul.
Then you could check if you got power at the relay socket, ....terminal 30 unswitced, terminal 86 switched.
And that you got ground at terminal 85 for a couple of seconds, when the starter button is pressed.
If you don't measure ground at 85, check at the yellow/brown wire at the ignition ECU under the tank, which
is the other end of the wire (keep the ECU connected).
Still nothing.......check that you got power at the black/yellow wire at the ignition ECU, when pressing the
starter button.
If you got power at this wire......the ignition ECU is the problem.
Also check that the ECU itself have good ground, brown wire.
Post by: pdg on February 24, 2013, 02:10:24 PM
Wasn't aware it was already known - and where you went is where I was going next :laugh
I'll be in the corner playing with round nosed scissors...
Post by: Inge K. on February 24, 2013, 02:24:42 PM
Oh well........Grant is out and playing with some round nosed animals, down there in SA....
Post by: grant71 on February 25, 2013, 03:37:30 AM
thank you Paul. yes ign on when i push starter . lights ok horn ok all ok except she wont fire. batt ok starter ok. now Paul i am a novice. pretend im a 4 yr old. i bought a 12 v tester. un switched 30 lights up. switched 86 lights up. 85 ground i dont understand the GROUND terminology. wheni puttester on 85 and pushed starter NO light up.  btw i put alligator clip on batt earth. is that right? and the point of tester to the indicated 86 or 30 etc.
Post by: pdg on February 25, 2013, 07:58:16 AM
Ground is the common negative - the frame. Eventually, everything is connected to the frame and through this to the battery negative.
With the tester you have the available tests are somewhat limited, you can test for a ground (sort of) at the relay socket though... For normal use, you have it connected correctly with the clip/negative lead to the battery negative terminal.
Put something like a paperclip (or other handy sized bit of metal) into the hole for 85. Connect the tester alligator clip (-ve, negative, black lead??) to this and the other side of the tester probe (+ve, positive, 12v, red connection??) to the battery positive. When you press the starter this should light up briefly. This test won't tell you how good the ground is, like a proper meter would, but it's a rough indication.
You could see if the relay is operating (at least mechanically) if you have a couple of spare bits of wire - connect pin 85 to battery negative and pin 86 to battery positive - the relay should click...
Also, maybe try another relay? Any 12volt relay with the same pins in the same place will work - there is nothing special about the BMW relay. 15Amp should be sufficient, 30Amp is probably a better long term thing.
Alternatively, find someone with a proper multimeter who knows how to use it and get them to follow the tests Inge described - they are 'better' tests that will tell you more.
Post by: grant71 on February 25, 2013, 09:24:08 AM
thanks for that info Paul . i did as you suggested and pushed the starter. lit up briefly. i then usedwire to relay and  battery . the  relay clicked. does that tell me its working? there is 1 thing puzzling me. as i said im an amateur but the connectivity betw tank wire and wire on right side does not look original. looks like there is a shunt to accommodate a separate spare conn. say for gps or similar. ive taken a pic of this  arrangement but i cannot send it via motobrick. if you send me your em address privately then i can send it to you. that is of course if you d like to indulge me .he he ! my em 27763740208@vodamail.co.za im in Capetown and i reckon the time difference is 2 hours. thanks foryourinterest Paul and Inge.
Post by: frankenduck on February 25, 2013, 09:43:36 AM
To attach pictures to a post: Click on Attachments and other options below the text box and then click on the Choose File button.
Post by: grant71 on February 25, 2013, 10:12:07 AM
the reason i cannot attach pics is i use a very simple Chinese device which is a key board with a built in modem. from the  key board wires connect to my tv set and all my pics and text msgs are tv size. its called a Webbox and my service provider does the software viz. VODACOM . this device only costs about 45 US dollars. furthermore vodacom give 100 MB of data free every month for 1 year. 100 mb cost about 5.5 US dollars.  so any which way you look at it, it s a good deal
Post by: argent brick on February 25, 2013, 02:51:14 PM
Send it to me and tell me where you want it posted
Post by: grant71 on February 25, 2013, 03:10:06 PM
thank you Lynn. ill send a few pics to you for Workshop
Post by: Inge K. on February 25, 2013, 03:22:50 PM
As you now have confirmed that you got both power and ground signal at the relay socket,
next step would be to put the relay bck into the socket and measure if you got power at
fuse #6 for a couple of seconds while pressing the starter button.
You don't need to remove the fuse, you should be able to measure that on the top off the fuse.
Inge K..
Post by: grant71 on February 26, 2013, 07:39:40 AM
hi Inge. thanks for your tip. yes there is power  at the no. 6 fuse when i press starter
Post by: Inge K. on February 26, 2013, 11:53:23 AM
Fuse #6 sits between the relay and the tank connector, since you didn't measure any power
at the green/white wire on the fuel tank connector...you have a open circuit between these.
It could be a idea to check that the front fuse connector (output) is clean and tight.
Terminal 9 at the heat management relay is also connected to this circuit, wires is spliced
at the fuse output terminal.
Inge K..
Post by: grant71 on February 26, 2013, 01:18:39 PM
Where is terminal 9 and where is heat management relay
Post by: Inge K. on February 26, 2013, 03:59:28 PM
The heat management relay you find on the right side in the relay box,
it's white (light green, early models) and rectangular.
The different terminal codes is marked on the side of the relay housing.
Inge K.
Post by: grant71 on February 28, 2013, 09:45:11 AM
The fuel pump saga continues. Today i replaced the tank conn. Made sure the relevant wires mated. Took my tester clip on neg and point on the green / white wire on the tank side of the new conn. Pushed starter button. Tester lit up. Assembled the fuel tank conn the 2 fuel pipes. Pushed starter. BIKE WOULD NOT START. Checked for  spark. Yes plenty. I suppose the next step will be to empty tank and remove the pump. Any suggestions pse
Post by: Inge K. on February 28, 2013, 11:10:33 AM
Before you removing the pump, you could check if you got power (and ground) at the pump terminals.
Smallest terminal is the positive feed, ......it have been some issues with bad connection on the
common ground connection at the level sensor base.
While down there, also try to feel if it's any small movements on the pump when pushing the starter button.
And if, try to reverse the pump (change polarity) to remove crud from the internals.......if you're lucky,
and check if the screen under the pump is OK.
Inge K.
Post by: grant71 on February 28, 2013, 11:18:46 AM
Thanks Inge. Is nt it dangerous the mess about in the tank esp. Petrol vapour
Post by: Inge K. on February 28, 2013, 11:59:47 AM
As long you keep the test probe and clip tight against the pump terminals,
(and the test lamp internal connections is tight), it won't be any spark.
Inge K.
Post by: grant71 on March 02, 2013, 11:08:19 AM
Hi Inge. I ve taken petrol car off and looked inside the empty tank. Ill never get my hands in there. I am waiting for a flexible tool. I intend taking off the nuts on pump. Attaching a wire to each terminal and then the wires to the battery  to test pump. Is this the correct procedure and do i run pump for a milli second  - -DRY ? No petrol ?
Post by: frankenduck on March 02, 2013, 01:25:15 PM
That should work.  If you're just running the pump for a few seconds to test it then you should be OK running it dry.  I've done it lots of times.
Post by: grant71 on March 04, 2013, 10:06:24 AM
Ok. I did that and the pump runs perfectly. Now what. ? Do i check circuit from fuel level inside to pump terms ? Do i look at fuel press reg ? I am renewing fuel filter. Very little contamination
Post by: frankenduck on March 04, 2013, 10:20:27 AM
Check the continuity from the connector outside the tank to the fuel pump leads.  It's not unheard of for the wiring at the base of the fuel level sender to fail.  You'll probably need to replace the FLS if that's the case.
Post by: grant71 on March 04, 2013, 12:24:38 PM
As i see it the wires from f l s are brown pos and black neg. Now the pump is out of the tank. Which colour wires from conn are the ones to f l s ? Thank you for your patience
Post by: frankenduck on March 04, 2013, 01:47:00 PM
The lead to the fuel pump with the larger ring terminal(probably black) is ground - connects to brown outside of the tank.  The other one (probably a faded yellow) connects to the green/white outside of the tank.
Post by: grant71 on March 04, 2013, 04:54:37 PM
Now we are getting somewhere. I conn the tank pump wires to the pump and then took 2 wires direct to the battery. Pump worked. I then took same batt wires via the tank conn. Viz. Pos to green and neg to brown. Pump did NOT work. Looks like the  earth via the fuel level sensor is faulty. What is solution ? Thanks for your help. You are spot on re fuel sensor
Post by: grant71 on March 05, 2013, 05:24:21 AM
I took the fuel level out. No continuity. So i need another unit. What do you ask for a used fuel level unit ?
