TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: tsbt on February 21, 2013, 12:45:24 PM
Title: K1100rs fairings on a K100rs
Post by: tsbt on February 21, 2013, 12:45:24 PM
Hey ya'll.
Been buying some K1100 fairings which I'd like to get painted and put on my K100rs this summer. I like the look of them better than the stock K100rs'. I'm not sure if the mounting hardware/fairing bracket is the same. Has anyone done this? if so, you got any pics?
Cheers
Chris
Title: Re: K1100rs fairings on a K100rs
Post by: frankenduck on February 21, 2013, 01:02:44 PM
You'll be fine and everything will bolt right up. I fitted a K1100RS fairing to a K75. The only issue was the mounts/brackets on the frame near the top of the radiator since the K75 is "missing" a cylinder so those frame members angle back farther.  That won't be an issue on a K100.
(http://i82.photobucket.com/albums/j246/smithduck/k75fs.jpg)
Post by: tsbt on February 21, 2013, 01:05:32 PM
Thanks Duck. Nice to hear from you. I see you also chromed your rack. Nice touch.
Post by: frankenduck on February 21, 2013, 01:11:47 PM
Nope. That's an OEM part. (46542303558)
Post by: branandfox on February 21, 2013, 04:50:27 PM
Im doing the same thing tsbt! About to get the whole set repainted Lamborghini orange with new decals! good luck man.
Post by: Michael in AZ on February 22, 2013, 12:47:00 AM
Duck, curious as to how that fairing works in terms of the right side heat issue. Is the venting superior or is it the same song and dance for a 75 with full dress? Looks super sharp!
Post by: frankenduck on February 22, 2013, 08:01:47 AM
That's an old picture. My K75 actually has K1100RS side covers now.
(http://i82.photobucket.com/albums/j246/smithduck/2012/121210_k75f2ca/121210_day2a.jpg)
Like other Ks the K1100RS fairing does get warm in the thigh zone. One thing you can do is add a blanket of insulation under the tank.  In my case I added some perforated stainless grills to the lowers which restricts airflow to some extent so it's about a wash in terms of adding the blanket.  Not much of an issue for the temps I usually ride in though.
Post by: tsbt on February 25, 2013, 03:19:19 PM
Nice. I'll be following that story.
