MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: branandfox on January 15, 2013, 03:16:07 PM
Title: Look for seat hardware!!
Post by: branandfox on January 15, 2013, 03:16:07 PM
needing new seat hardware as my originals are all bent and what not.
Title: Re: Look for seat hardware!!
Post by: K75RT Keith on February 18, 2013, 08:42:17 PM
Might have a complete set.  Need the latch pin too or just the hinges?
Post by: frankenduck on February 18, 2013, 08:58:52 PM
FYI: They are different on 85 and earlier bikes vs. 86+ bikes.  (And different for K1100s too.)
Post by: branandfox on February 20, 2013, 02:35:43 PM
well duck I've got a K1100 rear cowl that im trading my old 85 rear cowl out for, So would I need the 85 hinge and hardware or the K1100 version? Im switching out my rear cowl and seat for a K11 cowl and a corbin.
Post by: frankenduck on February 20, 2013, 03:07:27 PM
If you're going with a K11 tail cowl then you'll be using a seat with an 86+ seat pan so you'll want 86+ hardware.  Be aware that K1100 seat pans dip down into the frame under the rider and are not compatible with the under seat tool box - but can be used with the low seat  version of the L-Jetronic holder.
The newer K1100 seat pans also need the newer (more expensive) hinges with rubber in them. (Although alternately you can use older hinges with a 1/2" spacer.)
Post by: branandfox on February 21, 2013, 06:45:34 AM
But the seat pan will be the Corbin canyon dual sport So will I need the 86+ hinges and my toolbox or the lower model. and if needed do you have any of what I need just laying around? haha
Post by: frankenduck on February 21, 2013, 07:30:23 AM
You'll be fine with the Corbin, 86+ hinges and normal toolbox. :2thumbup:
Sorry, can't help.
Post by: branandfox on February 21, 2013, 07:48:16 AM
Well I already have a laundry list of parts to buy from microfiche, whats a few more pennys eh?
Post by: K75RT Keith on February 22, 2013, 10:58:28 PM
The seat hardware I have is from a K75RT.  It may be the same as a K1100 but you'd need to check.
