TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: johnny on May 17, 2011, 10:32:59 PM
Title: Works Performance Shocks
Post by: johnny on May 17, 2011, 10:32:59 PM
i gotts the works performance steel tracker on the bugeye motobrick n i just ordered another for the squeaky curd motobrick...
this unit has triple rate springs... threaded pre load... adjustable rate suspension... remote reservoir...
(http://www.worksperformance.com/images/shocks_200h/bmw_steel_tracker_trs_tpl_ars_rez.jpg)
we travel continuously for work so we carry all of our hot weather gear n cold weather gear n dry n wet gear in our side bags which rolls the bugeye motobrick over the truck scales at 690 pounds...
then add our heavy motoport gear and my enormous stature and we roll over the truck scales 1220 pounds fully loaded 2up...
the folks at works performance were kind enough to take a closer look at our insatiable 2up aggressive canyon carving and suspension load... they said their stock components needed a rethink and ordered us some special valving and springs...
the works performance shock has been on the bug for more than 3 years... it has been 100% yeeeeeeeehaaaaaaaaa...
i called works performance to order a clone for the curd... i gave them my name and they looked up my previous order... they had all the details archived... they knew exactly what valving n springs i needed...
see the install n tweak manual here... (http://www.worksperformance.com/pdf/instructions/bmwk.pdf) works performance steel tracker...  (http://www.worksperformance.com/html/bmw_steel_tracker_trs_tpl_ars_rez.html)works performance is 100% pro... (http://www.worksperformance.com/html/home.html)
if you want... contact is tom... email tom@worksperformance.com phone 818-701-1010 ext 21...
tell him motobrick johnny sent you for 10% motobrick.com discount on new shocks and service...
