TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: moynistan on October 05, 2012, 03:04:49 PM
Title: Bulbs for dash pad switches?
Post by: moynistan on October 05, 2012, 03:04:49 PM
I am overhauling switches on my 4V K100 (91).  The 4 way flasher switch looks as though it has leads going to the empty socket under the hazard symbol.  Is there a bulb for this spot and if so what type, number, etc.?  Thanks in advance, and apologies if this is in the Lieberry, I searched with no luck.
Title: Re: Bulbs for dash pad switches?
Post by: frankenduck on October 05, 2012, 03:37:24 PM
The early hazard switches did have three wires to them and a little bulb inside that the flasher relay blinked with the turn signals.  It was part of the switch and not a separate part.
If you're going to fiddle with installing a light in there then I'd go with an LED:
http://www.newark.com/lumex/ssl-lx3044id-12v/led-t-1-red-6mcd-635nm/dp/09J9513 (http://www.newark.com/lumex/ssl-lx3044id-12v/led-t-1-red-6mcd-635nm/dp/09J9513)
Post by: moynistan on October 05, 2012, 09:49:44 PM
 :hmm:
Maybe someday when I don't have 15 other loose ends...thanks
